raxx
- Feb 20, 2022
Hello everyone, some time ago my system was in degraded state so I went ahead and replaced a drive.
System went to healthy state and everything is working fine for almost a year now. However the drive does not appear to be properly added, as it is missing from some key places.
Something must of been mixed up in my setup process, and potentially I might need to "replace" the disk with itself and resilver it, could I get some exact instructions and where I've must of went wrong. Thank you!
1) zpool status drive shows up as da5, without gptid prefix like every other drive.
2) In UI. It appears as if it does not belong to the pool, But it does!
3) Does not show up in `glabel status`
4) Does not show up in output of the `gpart list`
pool: Ultimate
state: ONLINE
scan: scrub repaired 0B in 06:36:08 with 0 errors on Sun Jan 23 06:36:13 2022
NAME STATE READ WRITE CKSUM
Ultimate ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/fc006c93-828a-11e9-be38-002590ded475 ONLINE 0 0 0
gptid/fcd5703f-828a-11e9-be38-002590ded475 ONLINE 0 0 0
mirror-1 ONLINE 0 0 0
gptid/fdf82f35-828a-11e9-be38-002590ded475 ONLINE 0 0 0
gptid/fedb7faf-828a-11e9-be38-002590ded475 ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
gptid/7db73753-8750-11e9-a106-002590ded475 ONLINE 0 0 0
gptid/e856c0d3-ea89-11ea-85d6-002590ded475 ONLINE 0 0 0
mirror-3 ONLINE 0 0 0
gptid/919d0a23-0880-11ec-a98c-002590ded475 ONLINE 0 0 0
gptid/0b29ea67-05f7-11eb-9a71-002590ded475 ONLINE 0 0 0
mirror-4 ONLINE 0 0 0
da5 ONLINE 0 0 0
gptid/81297c02-ea8a-11ea-85d6-002590ded475 ONLINE 0 0 0
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:15 with 0 errors on Tue Feb 15 03:45:15 2022
boot-pool ONLINE 0 0 0
da8p2 ONLINE 0 0 0
Name Status Components gptid/e856c0d3-ea89-11ea-85d6-002590ded475 N/A ada0p2 gptid/81297c02-ea8a-11ea-85d6-002590ded475 N/A ada1p2 gptid/fc006c93-828a-11e9-be38-002590ded475 N/A da0p2 gptid/fcd5703f-828a-11e9-be38-002590ded475 N/A da1p2 gptid/fdf82f35-828a-11e9-be38-002590ded475 N/A da2p2 gptid/fedb7faf-828a-11e9-be38-002590ded475 N/A da3p2 gptid/7db73753-8750-11e9-a106-002590ded475 N/A da4p2 gptid/0b29ea67-05f7-11eb-9a71-002590ded475 N/A da6p2 gptid/919d0a23-0880-11ec-a98c-002590ded475 N/A da7p2 gptid/f403c513-051e-11ec-b808-002590ded475 N/A da8p1 gptid/e1bfc35f-ea89-11ea-85d6-002590ded475 N/A ada0p1
