The current Transmission 2.61 plugin does not have any option to enable SSL for the web interface (/transmission/web/). I'd like to set up access to Transmission from WAN, but only using SSL. Does anyone have it already set up like that?
Edit #1: Perhaps it is just as simple as installing nginx into the jail like described in http://forums.freenas.org/showthread.php?10558-HOWTO-Serve-up-media-to-Roksbox-from-a-FreeNAS-jail and then use it as auth proxy like described on https://forum.transmissionbt.com/viewtopic.php?f=8&t=12532#p58558 ?
