Transmission and plex guide (help) TrueNAS scale
Antwan2022
I'm trying to trial TrueNas Scale before installing it to my proxmox cluster but it seams a lot less intuitive then core installing apps, Where before I could hit install then mount a folder with a simple user account and jail, I'm seeing loads of options at the install and set up etc im not used to no iv never used docker so that may be my issue if nothing else id just like advice to I can learn for iv done some searching but all i find is people with the same issue.
Thanks in advance
Kris Moore
SVP of Engineering
Administrator
If you are new to docker / Linux containers in general. I can tell you the options you really want to focus on are the host-volume mounts. Those are the similar functionality to on CORE where you mount a directory to inside your container. The other options you can experiment with more as you get comfortable :)
