Transmission 2.82 stopped working in 9.2.1.3
FunSkilZZ
i recently updated my freenas to 9.2.1.3, i tried restarting it but that didn't work.
i re installed the plugin, that worked but after 2 days it suddenly stops and i can't turn it back on again :/ someone got any clues ?
Yatti420
Specs please.. Any message in /var/log/messages?
FunSkilZZ
Yes sure but help me out a bit more where to find everything. I'm learning bit by bit :D
the log where do i find that ?
specs : amd athlon x2 64 4800+
4gb ram
abit g-lan i think :/ 2x2tb wd red drives
FunSkilZZ
the logfile ? is it the green one on the bottom of the freenas GUI ?
Apr 6 14:31:33 freenas notifier: Performing sanity check on nginx configuration:
Apr 6 14:31:33 freenas notifier: nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
Apr 6 14:31:33 freenas notifier: nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Apr 6 14:31:35 freenas mDNSResponder: mDNS_Execute: SendResponses didn't send all its responses; will try again in one second
Apr 6 14:34:22 freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs list -H -o name /mnt/volume01/SERVER/.warden-template-pluginjail
Apr 6 14:34:22 freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/volume01/SERVER/transmission_1
Apr 6 14:35:50 freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs list -H -o name /mnt/volume01/SERVER/.warden-template-pluginjail
Apr 6 14:35:50 freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/volume01/SERVER/transmission_1
D
dlavigne
Guest
Type more /var/log/messages in the shell of the GUI and use the spacebar to read through the file. Paste the lines that deal with transmission.
Also post the output of ifconfig.
FunSkilZZ
i found that command on google, i tried it but freenas responds with a permission denied.
i'l check for ifconfig when i'm back
FunSkilZZ
this is what i get when i type the /var/.....
[root@freenas ~]# /var/log/messages bash: /var/log/messages: Permission denied
and this for the ifconfig :
[root@freenas ~]# ifconfig
nfe0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=82008<VLAN_MTU,WOL_MAGIC,LINKSTATE> ether 00:19:66:8d:b1:f1 inet 192.168.1.100 netmask 0xffffff00 broadcast 192.168.1.255 inet 192.168.1.101 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (100baseTX <full-duplex>) status: active ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536 nd6 options=9<PERFORMNUD,IFDISABLED> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5 inet 127.0.0.1 netmask 0xff000000
FunSkilZZ
i found something tha had to deal with permissions, dind't help, updating to the new released BETA dind't word.
the attached file is what i got
  • log 11-04-2014.txt
