Hey I'm new to the community and all this thing called FreeNAS and after I've defined everything and everything worked (and I have to say lucky to have this community because I've also used the posts of others here)
But after everything was set I started copying and it copied at a rate of only 11.4M / S and I really checked everything from the router settings to everything webUI and everything was normal and this problem is not only reading WIN in my Mac so I really do not know what the problem I use The connections in CAT6 to Switch and the switch to the router have CAT7 so there is no problem of cable and NAS and the computer I tested has a 1GB network card (the switch supports up to 100MB and I do not currently have the ability to upgrade to a 1GB switch) but there is some way to speed up I know I Will not get the 100 MB of the switch but at least 70MB it would be excellent
Thanks Itay
Thanks Itay
