kbrvfx
- Dec 6, 2020
Good day everyone!
So I just made a nas server out of old pc components here in our office and with a cat6 lan cable, it is connected to the router. My main issue right now is the transfer speed (wifi - lan).
I also performed an iperf test between server (lan) and client (wifi - 350 Mbps adapter 801-b\g\n) and this is the result:
I did try to use the same cable on a working pc and it did detect as 1 Gbps (it was an h81 board) then proceeded to create a shared folder to test the speed (transfer file from wired pc to the other pc with a 350Mbps wifi adapter), however the speeds are the same which is around 9-11 MB/s on both from wired pc to wifi pc and vice versa and sometimes it goes up to 17-18 MB/s but goes down directly.
My main concern is that, could it be that I have to change config on my old server bios to change 100Mbps to 1000Mbps? Since the board supports Gigabit network?
I've considered these solutions for this problem of mine:
Client connecting to 192.168.1.22, TCP port 5001
TCP window size: 208 KByte (default)
[ 3] local 192.168.1.9 port 1236 connected with 192.168.1.22 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 99.5 MBytes 83.3 Mbits/sec
Mobo: msi fm2-a75ma-p33
Cpu: am4 5300
Ram: 8gb ddr3
Storage: 500gbx3 old drives
Cpu: am4 5300
Ram: 8gb ddr3
- Convert network system to lan-lan (with switch & cat6 lan cables instead of wifi to server)
- Get an intel NIC (but so rare to find in our country)
- Get a mobo with an intel NIC (Since I heard that realtek NIC's are junk)
