Good afternoon. I'm running TrueNAS Scale ver. ___ and am trying to install traefik 2.10.1_18.0.14 but am getting the following error when trying to install:
[EFAULT] Failed to install chart release: Error: INSTALLATION FAILED: unable to build kubernetes objects from release manifest: resource mapping not found for name: "traefik" namespace: "" from "": no matches for kind "ServiceMonitor" in version "monitoring.coreos.com/v1" ensure CRDs are installed first.
Under the More info tab, TrueNAS displayed the following log info:
Any help with getting this resolved would be greatly appreciated! Thank you!
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 461, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 486, in do_create await self.middleware.call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1346, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1249, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/helm.py", line 44, in helm_action raise CallError(f'Failed to {tn_action} chart release: {stderr.decode()}') middlewared.service_exception.CallError: [EFAULT] Failed to install chart release: Error: INSTALLATION FAILED: unable to build kubernetes objects from release manifest: resource mapping not found for name: "traefik" namespace: "" from "": no matches for kind "ServiceMonitor" in version "monitoring.coreos.com/v1" ensure CRDs are installed first
