flashdrive
- Apr 2, 2021
Is there a way to tell Samba to use a NIC / Mac Address / etc. as a primary NIC?
I have 2 NIC ports active:
1. which is WiFi via adapter
2. 10 GBit LAN
How do I set up that Samba will use 2. - 10 GBit LAN ?
the reason for the wifi connection is mentioned here:
2. 10 GBit LAN
start TN host other than Wake on LAN - no more LAN cable available (no ILO)
Hello, I want to start the host remote. The problem is that I do have only 1 available LAN cable to connect. This goes to the HPE NIC, which will not work with WoL (although it is supposed to do so) The lights of the HPE NIC ports go out once the host is shut down. This is not true for the...
www.truenas.com
