tmpfs in jail?
dirkme
Hi Guys,
I still haven't given up yet to get Plex to transcode into a ram disk.
When i am in a terminal in my jail and try to do
mount -t tmpfs tmpfs	/tmp
I get a "not permitted"
I then tried this in /etc/rc.conf
tmpmfs="YES"
tmpsize="100m"
tmpmfs_flags="-S"
and added:
tmpfs /path/to/the/directory tmpfs rw 0 0
in the jail /etc/fstab.
But i don't think it worked (course I restarted the jail etc.)
Any ideas?
SweetAndLow
Sweet'NASty
If you ever get this running I would love to see your performance changes and the numbers showing an improvement. I assume latency would improve but I have my doubts about it making a difference.
wblock
Documentation Engineer
dirkme
It is more about reducing the read write stress on my hdds. Transcoding in ram leaves it without any read and write on my physical hdds.
SweetAndLow
Sweet'NASty
Ok but it's not stressful. Disks are meant for reads and write. So again if love to see your tests that show this is better in some way.
wblock
There is a setting for allow.mount.tmpfs for FreeBSD jails. See jail(5).
dirkme
So.... you guys let me die stupid ;-)
I would guess it goes in /etc/boot.conf?
wblock
No. On FreeBSD, it would go in /etc/jail.conf. On FreeNAS 11, it is probably done through iocage.
Jakob Tewes
In an iocage jail, you have to set the required parameters like this
iocage get all jailname | grep allow_mount_tmpfs
-> initially set to "0", must be "1"
iocage get all jailname | grep enforce_statfs
-> initially set to "2", must be below "2"
iocage set allow_mount_tmpfs=1 jailname
iocage set allow_mount=1 jailname
iocage set enforce_statfs=1 jailname
Please let me know, if there is a performance change :-9
