robbrown99
- Nov 3, 2020
Hi all
I am currently a ZFS user (using default ubuntu packages) and have a 2 6TB mirror in my internal bay (in an old Mac Pro running Linux Mint). Canonical posted recently that they will be no longer including support for ZFS in Ubuntu. As a Linux Mint user, this will eventually affect me so I am trying to get ahead of this.
I having been trying out TrueNAS (and Unraid) for a week. ZFS has been really good to me (a decade of use with no data loss despite drive loss), and I like the opensource nature of TrueNAS so I would like to stick with the ZFS file system and not go down the BTRFS route that unraid offers.
I have an old Dell 3470 desktop (Inte Core i3-8100 CPU @ 3.60GHz, 8GB RAM, integrated graphics) that may be a good candidate for a NAS box as it is a relatively fast quad core, . Unfortunately it only has room for 1 drive (and the motherboard is proprietary) , so I have to buy an external enclosure and connect via USB 3.0. However looks like power consumption of it (plus an external enclosure) is going to be fairly low.
My use cases:
- storing my photo collection (currently 1.5TB), backing up my computer
- backing up the family computers in the house (likely I would create separate shares for each one)
- potentially running a plex server or similar to share family photos and videos to our TVs. I haven't found anything that good yet that is similar to Synology Photos though.
- potentially running gaming servers for my kids (although options on TrueNAS seem to be far more limited than UnRaid)
- password tool like bitwarden
- potentially nextcloud
Some questions:
1) Regarding the external enclosure, it would have to always be powered on. I will have to find a JBOD enclosure that has a hard power switch to allow it to restart if the power is cut.
a) I assume in need an enclosure that does not automatically idle the drives via the enclosure's firmware?
b) Does TrueNAS support idling the drives via the TrueNAS OS? If so would this work to an external enclosure?
Context for question: seems not great to have the drives always on if they aren't being used.
2 - Creation of a zpool
2a) Is it possible to just export the zpool from my main computer, then install the two drives into the enclosure connected to the NAS, then import the pools into TrueNAS?
2b) I like the idea of the additional redundancy that RAIDZ2 offers. As I currently have a mirror, is it possible to convert the existing pool into a RAIDZ2 (3 drives), or does this have to be done at the time of pool creation? If so I would theoretically need to:
- buy 3 more drives of the same size, install into the enclosure, create RAIDZ2 3 disk array, then copy contents of my old zpool to the new one. I would imagine this is the least risky option.
- I guess I could optionally remove one from the existing mirror and move that one to the NAS enclosure and add two new drives into a brand new RAIDZ2 3 disk array, but I would imagine this is risky.
3) I have looked at buying a used dell server tower instead ($150-$250), but not sure if I am gaining much there other than an old more used box than what I currently have. eg. I found a used Dell T320 with 8 bays for $150, or a used Dell 5820 for $250 (barebones no GPU or RAM), or loaded $350 (inc RAM, quadro 4000, single SSD)
5) Is it possible to configure TrueNAS to sleep and then wake on LAN? Or does it always have to be running?
And yes, I am aware of the backup rules of not ttrusting it all on the NAS. I currently do a backup of my zpool to a single HDD that I put into a fireproof safe monthly. I would keep doing that.
Thank you
My existing pool:
My use cases:
Some questions:
Thank you
My existing pool:
rbrown@rbrown-MacPro:~$ sudo zpool status pool: BigDiskZFS state: ONLINE scan: resilvered 576K in 00:00:01 with 0 errors on Fri Jan 1 13:54:41 2021 config: NAME STATE READ WRITE CKSUM BigDiskZFS ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 sdd ONLINE 0 0 0 sdc ONLINE 0 0 0
