TimeMachine Old Macs
Hi all
I upgraded the Freenas core 12 to FreeNAS Scale 22 and now all my time machine shares are gone
With a new mac with Monterrey, all works well and i can save all my work
But on my older macs ( OS X el Capitan 10.11.6 ) the shares disappear , i think that these mas uses AFP to see / store to the time machine
So, please is there a way in order to my old macs use the scale time machine ??
thanks all
No.
AFP isn't supported on SCALE and those older MacOS versions don't do TimeMachine on SMB.
@enrique ortiz
I believe TrueNAS CORE still supports AFP TM shares. Hopefully, you preserved a CORE boot environment or have a config backup of CORE to revert back.
BTW, it's no longer FreeNAS
hi all
thanks to all I roll back to freenas core using the boot environment , Now all my Timemachine works ok
