Hi all,
OK, so down to the last thing to get everything working the way I want it. Worst is - it used to run just perfect!!! Grr...
Anyhow : Followed docs to a T, but my Mac (Mac Mini, circa 2008) doesn't see the TimeMachine share half the time. The other half, it will see it, but tells me the share is unavailable right as backup commences. (In those instances, I see a quick 2-second logon for "studiomac", my Mac Mini username, in the console.)
If I stop AFP and restart, half the time, I'll get this kind of spam every second or so :
Apr 14 16:59:12 freenas-server kernel: <118>Apr 14 16:59:12 freenas-server afpd[10106]: main: no servers configured
Apr 14 16:59:13 freenas-server netatalk[10083]: Restarting 'afpd' (restarts: 9)
Apr 14 16:59:13 freenas-server afpd[10108]: dsi_tcp_init: no suitable network config for TCP socket
Apr 14 16:59:13 freenas-server afpd[10108]: no suitable network address found, use "afp listen" or "afp interfaces"
Apr 14 16:59:13 freenas-server afpd[10108]: main: no servers configured
Apr 14 16:59:13 freenas-server kernel: <118>Apr 14 16:59:13 freenas-server afpd[10108]: dsi_tcp_init: no suitable network config for TCP socket
Apr 14 16:59:13 freenas-server kernel: <118>Apr 14 16:59:13 freenas-server afpd[10108]: no suitable network address found, use "afp listen" or "afp interfaces"
Apr 14 16:59:13 freenas-server kernel: <118>Apr 14 16:59:13 freenas-server afpd[10108]: main: no servers configured
Apr 14 16:59:14 freenas-server netatalk[10083]: Restarting 'afpd' (restarts: 10)
Apr 14 16:59:14 freenas-server afpd[10109]: dsi_tcp_init: no suitable network config for TCP socket
Apr 14 16:59:14 freenas-server afpd[10109]: no suitable network address found, use "afp listen" or "afp interfaces"
Apr 14 16:59:14 freenas-server afpd[10109]: main: no servers configured
Apr 14 16:59:14 freenas-server kernel: <118>Apr 14 16:59:14 freenas-server afpd[10109]: dsi_tcp_init: no suitable network config for TCP socket
Apr 14 16:59:14 freenas-server kernel: <118>Apr 14 16:59:14 freenas-server afpd[10109]: no suitable network address found, use "afp listen" or "afp interfaces"
Apr 14 16:59:14 freenas-server kernel: <118>Apr 14 16:59:14 freenas-server afpd[10109]: main: no servers configured
Apr 14 16:59:15 freenas-server netatalk[10083]: Restarting 'afpd' (restarts: 11)
Apr 14 16:59:15 freenas-server afpd[10111]: dsi_tcp_init: no suitable network config for TCP socket
Apr 14 16:59:15 freenas-server afpd[10111]: no suitable network address found, use "afp listen" or "afp interfaces"
Apr 14 16:59:15 freenas-server afpd[10111]: main: no servers configured
Apr 14 16:59:15 freenas-server kernel: <118>Apr 14 16:59:15 freenas-server afpd[10111]: dsi_tcp_init: no suitable network config for TCP socket
Apr 14 16:59:15 freenas-server kernel: <118>Apr 14 16:59:15 freenas-server afpd[10111]: no suitable network address found, use "afp listen" or "afp interfaces"
Apr 14 16:59:15 freenas-server kernel: <118>Apr 14 16:59:15 freenas-server afpd[10111]: main: no servers configured
Ideas...?
Thanks!
EDIT : Forgot to say, but the Mini is connected via WiFi. It used to work fine though....!! Up until I re-made my pool...
Ideas...?
Thanks!
