Hi all,
I got a rsync problem since I upgraded my FreeNAS-11.3-U5 to TrueNAS-12.0-U6.1.
I use software for backup named Backup Assist and the saves used rsync for backup data.
Since I upgrade to TrueNAS 12, the rsync transfer don't want to works and the error appear:
This is the command used by Backup Assist for the backup on my pool:
and after that, the error appears.
This is not possible to change the command launched by Backup Assist, so I can't change the -a compression by -zz or simply remove the -a.
There is a possibility to solve this rsync problem?
There is a possibility to downgrade the rsync version without breaking the TrueNAS?
If I forgot some information, I apologize in advance.
Regards,
Jean-Yves.
Version: TrueNAS-12.0-U6.1
CPU: Intel(R) Xeon(R) E-2224 CPU @ 3.40GHz
Memory: 15.9GiB with ZFS Cache: 9.9 GiB
Total Disks : 4 (data) RAIDZ1, Model WDC, type HDD
2 (caches), Model:256G TOSHIBA, type SSD
Ethernet: Media Subtype: 1000baseT with no vlan
rsync: This rsync lacks old-style --compress due to its external zlib. Try -zz. rsync error: syntax or usage error (code 1) at main.c(1592) [server=3.1.3] rsync: connection unexpectedly closed (0 bytes received so far) [sender] rsync error: error in rsync protocol data stream (code 12) at io.c(601) [sender=3.0.7]
C:\ProgramData\BackupAssist v11\temp\Rsync\rsync.exe -a -z --no-owner --no-group -H --chmod=u+w,a+rX --out-format="%o:%l:%b:%f:%i" -ii --modify-window=2 --filter=". /cygdrive/C/Users/Administrateur.WIN-VE07FNB77GJ/AppData/Local/Temp/47/l4xzutrb.ujf" --8-bit-output --progress --rsh="'/cygdrive/C/ProgramData/BackupAssist v11/temp/Rsync/ssh.exe' -o PasswordAuthentication=no -o KbdInteractiveAuthentication=no -o StrictHostKeyChecking=yes -o UserKnownHostsFile='\"/cygdrive/C/ProgramData/BackupAssist v11/.ssh/known_hosts\"' -i '/cygdrive/C/ProgramData/BackupAssist v11/.ssh/ba_id' -o ServerAliveInterval=60 -p 22" "/cygdrive/C/Users/Administrateur.WIN-VE07FNB77GJ/AppData/Local/Temp/47/0igjctsi.om1/" "rovatti_sav@backup.antsys.fr:~/save_quotidienne"
root@FREENAS01:~# rsync --version
rsync version 3.1.3 protocol version 31
Copyright (C) 1996-2018 by Andrew Tridgell, Wayne Davison, and others.
Web site: http://rsync.samba.org/
Capabilities:
64-bit files, 64-bit inums, 64-bit timestamps, 64-bit long ints,
socketpairs, hardlinks, symlinks, IPv6, batchfiles, inplace,
append, ACLs, xattrs, iconv, symtimes, no prealloc
rsync comes with ABSOLUTELY NO WARRANTY. This is free software, and you
are welcome to redistribute it under certain conditions. See the GNU
General Public Licence for details.There is a possibility to solve this rsync problem?
Regards,
Jean-Yves.
