Ben Edwards
 - Jul 18, 2015
Hi, I'me thinking of using FreeNAS at a small charity and wondering if the following setup will work (and have a few questions).
We have a Dell DC7700 1.8Ghz dual core PC which we can put 4GB of memory in. We will only 4 users (maybe 6 at some future time). Hopefully this is OK. We will mainly be storing documents and possibly some photos (not planing on using it for video). We will be using a 2TB drive for subsystem and files (I dont think the PC can take 2 drives).
We will be using windows clients (windows 7 but will probably be 10 soon). Wondering if it would work with XP (trying to avoid this my be good to know). Planing on using SAMBA.
We wish to have external access via VPN. Thinking of getting a Cicco RV42 router but could run VNS server on FreeNAS. Found references in FreeNAS documentation, does it work well/is it reactively east to set up. Not sure how this works in terms of wiring broadband router etc. Am I correct in thinking if I run VPN on FreeNAS box I would have to put it in DMZ, which makes me thing using the Ciso hardware may be better.
We also want to do offsite incremental backups (Apple timemachine style so we can go back easily to get previous version of files). Am running a second box offsite for this (possibly a laptop wit USB3 external drive). If there is a good FreeNAS plugin could use this otherwise was thinking of using Win7 and Genie8 Genuine timeline backup software.
Regards,
Ben
Regards,
Ben
