The volume "Volume1" (ZFS) state is UNKNOWN:
SmallGuy
Seub
Salut à tous !
J'ai fait un "smartctl -t long /dev/ada3"
[root@freenas] ~# smartctl -a /dev/ada3
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p5 amd64] (local build)
Model Family:     Seagate Barracuda 7200.11
Device Model:     ST3500620AS
Serial Number:    9QM2DVM9
LU WWN Device Id: 5 000c50 00b924de1
Firmware Version: SD15
User Capacity:    500,107,862,016 bytes [500 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Mon Jun  8 09:29:58 2015 CEST
==> WARNING: There are known problems with these drives,
THIS DRIVE MAY OR MAY NOT BE AFFECTED,
see the following web pages for details:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/207951en
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=632758
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  634) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 118) minutes.
Conveyance self-test routine
SCT capabilities:              (0x103b) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   109   099   006    Pre-fail  Always       -       22166654
  3 Spin_Up_Time            0x0003   095   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       590
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   079   060   030    Pre-fail  Always       -       4382395513
  9 Power_On_Hours          0x0032   096   096   000    Old_age   Always       -       4228
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       2
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       591
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   096   000    Old_age   Always       -       1467
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   061   057   045    Old_age   Always       -       39 (Min/Max 24/39)
194 Temperature_Celsius     0x0022   039   043   000    Old_age   Always       -       39 (0 12 0 0 0)
195 Hardware_ECC_Recovered  0x001a   028   028   000    Old_age   Always       -       22166654
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%      4224         -
# 2  Short offline       Completed without error       00%      4221         -
# 3  Short offline       Completed without error       00%      4220         -
# 4  Short offline       Completed without error       00%      4220         -
# 5  Short offline       Completed without error       00%      4219         -
# 6  Short offline       Completed without error       00%      3880         -
Pour les tests smart, je suis allé dans TASK/ TEST S.M.A.R.T
j'ai mis ada1 à ada4
Toutes les 6h, tout les deux jours, tout les mois et tout les jours de la semaine sont cochés.
Bidule0hm
Server Electronics Sorcerer
Ada3 est ok pour moi mais l'attribut 195 a augmenté de 100 k depuis la dernière fois. Je me demande si c'est normal ou non.
Donc en gros ça veut dire que tu fais un test tous les deux jours à 6:00 ? si oui c'est un peu trop souvent, les tests longs testent toute la surface du disque donc ils sont stressant pour le disque, en général on conseille pas plus d'un test long par semaine. Par contre tu peux faire un test court par jour si tu veux (attention à ne pas en faire le jour du test long) ;)
Seub
195 - Hardware ECC Recovered - Temps entre les erreurs corrigées par code correcteur (augmente et diminue, une faible valeur est probablement mauvaise).
Pour les test, c'est des tests smart courts, mon NAS n'est allumé qu'une fois par mois, à la fin du mois pour y balancer mes sauvegardes, le reste du temps il est éteint.
Pour moi aussi les disques devraient être bons, ils sont surement trop vieux ou alors ça viendrait du pc ?
Je vais tester avec un nouveau disque, on verra bien.
Bidule0hm
Yep, j'ai été voir sur wiki aussi, ça semble donc être bon ;)
Ah ok.
Quelle carte-mère tu utilises ?
Bidule0hm
Hum... c'est pas impossible que ce soit le contrôleur SATA, mais je n'y crois pas trop.
Essaie de remplacer les disques (et les câbles tant que t'y es) et on verra ce que ça donne ;)
Seub
Bonjour à tous,
Et bien me revoila le nouveau disque à la main.
J'ai fait le bourin, j'ai enlevé le disque ADA3 pour mettre le nouveau.
J'ai démarré ma machine mais quand je fais un zpool status, il me met la même chose qu'avant, (disque 3/4 HS) que faut-il faire pour remplacer correctement un disque dur ?
C'est bon j'ai trouvé,
Dans STORAGE
Aller Dans
Puis cliquer sur le disque UNAVAIBLE Cliquer sur REPLACE
Le disque est réimporté, (ça prends du temps)
Merci !
SmallGuy
Petit conseil:
Plutôt que de procéder à taton, il est recommandé de suivre scrupuleusement la documentation à laquelle on accède par le lien en haut de la page du forum.
Il n'y a rien a deviner ou à inventer.
Ravit cependant que tu sois parvenu à tes fins.
