Hi i'm getting Error 0x80070035 - The network path was not found when i try to access my Freenas system. It doesn't happen all the time but it happens alot, any reason why this happens?.
What protocol do you use to access the files? How are the computers connected - string, ??
If wireless - expect it to be sucky. If wired - tell us the make/model of your NICs. Do you have gigabit networking? If connected to a router or switch tell us the make/model.
I do use it wireless and gathered that i'd get some connection drops but not as much as it has been. The router/modem is a Virgin Media Super Hub 2 and i have connected to a TP-Link TL-SG1008D Gigabit Switch thats connected to my wired devices like my htpc's
What annoys me is its doing this more than it had done, I have to go in to adapter settings and disable the wireless card and enable and it picks up. Then after a while its gone again.
Well, you can prove if its a wireless problem or not. Disable wireless and connect via a wire. If the drops stop, then its definitely the wireless. But, considering that 99.9% of everyone that has every had a problem that used wireless found the problem to be the wireless, you probably have the problem and the solution.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
