Not having much luck with upgrading my second FreeNAS box so I thought I'd try and upgrade the original one from FreeNAS-11.2-U5
to TrueNAS-12.0-STABLE
and get this error
Is there someting wrong with it? I've never touched it.
and get this error
The following Inconsistencies were found in your Current Install:
List of Checksum Mismatches:
Close
/boot/defaults/loader.conf
| Here is /boot/defaults/loader.conf:- |
exec="echo Loading /boot/defaults/loader.conf"
kernel="kernel" # /boot sub-directory containing kernel and modules
bootfile="kernel" # Kernel name (possibly absolute path)
kernel_options="" # Flags to be passed to the kernel
loader_conf_files="/boot/device.hints /boot/loader.conf /boot/loader.conf.local"
nextboot_conf="/boot/nextboot.conf"
nextboot_enable="NO"
verbose_loading="NO" # Set to YES for verbose loader output
splash_bmp_load="NO" # Set this to YES for bmp splash screen!
splash_pcx_load="NO" # Set this to YES for pcx splash screen!
splash_txt_load="NO" # Set this to YES for TheDraw splash screen!
vesa_load="NO" # Set this to YES to load the vesa module
bitmap_load="NO" # Set this to YES if you want splash screen!
bitmap_name="splash.bmp" # Set this to the name of the file
bitmap_type="splash_image_data" # and place it on the module_path
screensave_load="NO" # Set to YES to load a screensaver module
screensave_name="green_saver" # Set to the name of the screensaver module
entropy_cache_load="YES" # Set this to NO to disable loading
# entropy at boot time
entropy_cache_name="/boot/entropy" # Set this to the name of the file
entropy_cache_type="boot_entropy_cache" # Required for the kernel to find
# the boot-time entropy cache. This
# must not change value even if the
# _name above does change!
ram_blacklist_load="NO" # Set this to YES to load a file
# containing a list of addresses to
# exclude from the running system.
ram_blacklist_name="/boot/blacklist.txt" # Set this to the name of the file
ram_blacklist_type="ram_blacklist" # Required for the kernel to find
# the blacklist module
acpi_dsdt_load="NO" # DSDT Overriding
acpi_dsdt_type="acpi_dsdt" # Don't change this
acpi_dsdt_name="/boot/acpi_dsdt.aml"
# Override DSDT in BIOS by this file
acpi_video_load="NO" # Load the ACPI video extension driver
# Default is unset and disabled (no delay).
autoboot_delay="3" # Delay in seconds before autobooting,
# -1 for no user interrupts, NO to disable
bootenv_autolist="YES" # Auto populate the list of ZFS Boot Environments
module_path="/boot/modules;/boot/dtb;/boot/dtb/overlays" # Set the module search path
# If the TFTP server does not support RFC 2348,
# the block size is set to 512. Valid: (8,9007)
# Sets the list of init candidates
# registration, useful for USB sticks as root
