Hello all,
I'm facing the following task and I tend to solve it with two FreeNAS boxes and or with a plugin;
One company with two sites and they are connected through a bad/low bandwidth via site2site vpn which works but the access from the remote site via vpn to the FreeNAS via SMB is obvious slow so I need to find a smart solution to deal with it.
My first idea was to put a second FreeNAS at the remote site offering a local SMB access to solve the low bandwidth and to keep the data up2date with replication BUT how to deal with data inconsistencies?
I think this is not right way, isn't it?
The second idea is to solve it using btsync or syncthing as a plugin/jail at the main FreeNAS?
What do you think?
What do you think?
