Tank reaching 97%
But why the process did not change after hours.
Because you have a pool consisting of a single, twelve-disk vdev, with resulting horrible IOPS. And another disk that's showing lots of problems too.
Ouch, 4.37KB/s?!
And 6 data errors? That pool is a goner. You'll want to destroy it and make a new one (with a more sane layout).
farmerpling2
The slowness likely occurs because of the degraded disk drive, is my guess.
You could do a clear to reset the error count and see if the error count is going up.
The data may be suspect, though.
You want 5 or 6 TB drives and go Z2 or Z3... Only reason to use Z3 is because of the lack paying attention to the RAID system.
...if by "suspect" you mean "known to be defective"...
For 20 TB of block storage? For block storage workloads, that means about 40 TB of net capacity. Ten 5 TB disks in RAIDZ2? It'd be an improvement over what's there now, but...
dnet
After a week without changes to the resilvering process, it may be necessary to restart the machine.
Chris Moore
Stux
The filesystem that's using the extent is presumably not going to react well to sudden shrinkage of the underlying disk, so that would require one or more of the following:
  • Nuke it, restore from backup to a new share that is properly configured to not allow for the pool to get so full.
  • Add more storage.
  • Get rid of snapshots.
  • Move other data elsewhere.
For future reference, by writing zeros across free space, assuming compression on ZFS is enabled (it is by default), you should actually be able to get some space back.
jgreco
Resident Grinch
40TB or ideally more, 60TB wouldn't be unreasonable. And not in RAIDZanything.
Yes, writing zeros to freed space on the client side of the block device should work as a crude stand-in for TRIM/UNMAP.
