Taking/deleting snapshots outside jail
fcorbelli
Is it possible, from an application within a jail, to take (and perhaps even delete) snapshots from a 'global' dataset?
"Global" in the sense of "outside the jail"?
The aim is to use backup applications, based on snapshots of TrueNAS datasets, from within a jail.
Thanks for any reply
jgreco
Resident Grinch
Yes. Set up sshd on the host NAS to accept ssh connections from the jail. Then you may issue whatever commands you wish, and you can even scope the allowed access if you run it via sudo.
fcorbelli
Therefore only with a ssh session?
jgreco
Resident Grinch
No. It's computer science. There's a thousand ways to do it, many more stupid than others. The upsides to ssh would be that it's an exceedingly clean and flexible interface by which to do this.
fcorbelli
It certainly will be, but it requires the use of a tool (ssh) that requires some configuration.
So is it not possible, even by "dirty" and "inflexible" methods, to do something like "zfs snapshot something" ?
Basically something that can be used in a script, without running commands through ssh
You could conceptually delegate a dataset to a jail, but the jail would have full control of it (more or less). This may or may not be what you're looking for.
fcorbelli
Seems promising.
Is it possible via GUI?
And how?
fcorbelli
If that's a dealbreaker, you'd always need a remote shell of some sort. SSH, is the sanest and most popular option for the majority of scenarios.
jgreco
Resident Grinch
Also the most portable. Otherwise you certainly have options such as the TrueNAS API, or less-recommended methods especially ones involving a helper outside the jail. But these basically just work out to being functional variations on doing it via SSH.
fcorbelli
There is an alternative, but it has strengths and weaknesses (i.e. use program outside the jail)
I think that, albeit not enthusiastically, I will opt for this choice
jgreco
Resident Grinch
I literally just said in my last reply "a helper outside the jail".
:rolleyes:
The proper way to do this is to have your helper executable located inside the jail filesystem namespace but launch it in the host system. On TrueNAS, you can do this with a startup task.
