First, here's what I'm trying to do. I have a FreeNAS 9.3-stable server to which I back up data from from several Linux, mac and windows clients around the house. Using the FreeNAS GUI, I have scheduled ZFS snapshots on my main dataset. I desire to maintain an offsite backup of the NAS, and I want that data to be encrypted. My plan was to install GPG in a jail, and then set up a periodic task in the GPG jail that effectively does an incremental zfs send to a remote host, by piping the output through GPG and then SSH to my remote host. My current status is:
- ZFS snapshots working from FreeNAS
- Commands like 'zfs list -t snapshot' work from the FreeNAS command shell
- Incremental 'zfs send -i' commands working from the FreeNAS command shell
- GPG installed in a jail and working
- FreeNAS dataset source and destination added/configured/mounted in the GPG jail
- GIDs and UIDs set up in the GPG jail to be consistent w/their FreeNAS counterparts
- I can access and see the FreeNAS dataset from the GPG jail command shell
- I can cd to the .zfs directory of interest from the GPG jail command shell and 'see' the snapshots w/ls, cat, etc
- Commands like 'zfs list -t snapshot' DO NOT WORK from within the GPG jail command shell (command result: 'no datasets available')
It seems a bit odd that I can see the actual '.zfs' hidden files from that jail, but that the 'zfs list' and 'zfs send' commands don't work. Should I be able to use and manipulate the zfs snapshots from within the GPG jail? If so, what should I try next? Are some environment variables that need to be set?
Thanks for any pointers/ideas.
-Phil
-Phil
