System panic when entering a directory
tmueko
hi,
System works with 11.3. I can reboot and mount the encrypted fs.
With 12.0-U1 it panics (see screenshot).
Mainboard is X9DR3-F with 32GB RAM.
Pool is 12 x 6 TB raidz2.
Sometimes there is a "ZFS WARNING: Duplicated ZAP entry detected (empty)." in dmesg.
# zfs list -o name,dedup -H -r pool01 | grep -v "off$"
gives nothing, no dedup.
should I: stay with 11.3? Add more RAM?
Chris Moore
You probably need to submit a bug report on this. It is certainly something the developers need to know about.
tmueko
I found out, that it was the content of a jail: I diabled all jails (and one vm), did the upgrade and TrueNAS was running.
When trying to start the Jail, System panics (It was a jail for borg backup with an extra dataset mounted)
Created a new jail, mounted my dataset, installed borg and everything was fine.
Now I have the old jail and when I go to /mnt/pool/iocage/panic-jail/root/etc and double press [TAB] the server bombs ...
Where do I make a bugreport?
tmueko
Hi
I create a file from that dataset an created a bug report with a link of that file for download.
