System freezing and not responding after 5 min of starting up
Carlos D
It just started doing this today. I tried rebooting and i get the exact same result every single time. Absolutely nothing changed in my network configs or anything I can think of that could have caused this.
I can see the system starting with no indication of any errors and then I can access the webgui for about 5 min and then I get the error this site can't be reached as if it wasn't connected to the router anymore.
I already tried changing ethernet cables and it keeps doing the same thing.
My setup
ASROCK C2550D4I
16G ECC RAM
around 10tb of storage and using roughly half of it.
I can still access the ASRock admin page so the hardware is working, I'm guessing it's something with freenas that is crashing but I can't see any type of error showing up in the console, it just says web interface is at and the ip address. I tried looking for logs but I'm not sure which one would be the one that I need and where they are located.
So what is the fastest way to debug this? Can I just reinstall only the OS and do some sort of restore configs to have everything setup the way it was?
Thanks
