System Degraded - Cannot ID which drive at fault
mudshark
Howdy, folks.
You can see in the attached JPGs that I have (5) 3TB drives now running in a degraded status.
Most recent long SMART tests show no issues.
Older SMART tests showed a one-time issue with ada1 but that drive now is passing long SMART tests.
Likewise, some months ago ada3 had a one-time failure but the status showed degraded for only a short period of time. After subsequent SMART tests volume status showed "online".
I included any screen shot I thought will help.
I have the adax and corresponding drive serial numbers but do not know how to drill down on the degraded status to know what action to take.
Thanks.
Rich
Chris Moore
The SMART test runs internal to the drive, so there is no reason you can't run them all simultaneously. You should run a short test daily and a long test only once a week. Still, it is good that you are running tests. Looks like one of your drives is failing. The thing to do now is look at the results of the test. You do that by running the command smartctl -x /dev/ada1 and you could post the results here if you want help deciphering it. Just put the text inside code tags like this: [CODE] listing here [/CODE].
It should come out looking kind of like this:
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Gold
Device Model:     WDC WD6002FRYZ-01WD5B0
Serial Number:    xxxxxxxxxx
LU WWN Device Id: 5 000cca 255e8afa6
Firmware Version: 01.01M02
User Capacity:    6,001,175,126,016 bytes [6.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Apr  4 23:57:12 2019 CDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  113) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 774) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
  2 Throughput_Performance  P-S---   138   138   054    -    100
  3 Spin_Up_Time            POS---   100   100   024    -    0
  4 Start_Stop_Count        -O--C-   100   100   000    -    1
  5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
  7 Seek_Error_Rate         PO-R--   100   100   067    -    0
  8 Seek_Time_Performance   P-S---   140   140   020    -    15
  9 Power_On_Hours          -O--C-   100   100   000    -    1346
10 Spin_Retry_Count        PO--C-   100   100   060    -    0
12 Power_Cycle_Count       -O--CK   100   100   000    -    1
192 Power-Off_Retract_Count -O--CK   098   098   000    -    2953
193 Load_Cycle_Count        -O--C-   098   098   000    -    2953
194 Temperature_Celsius     -O----   162   162   000    -    37 (Min/Max 25/38)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O---K   100   100   000    -    0
198 Offline_Uncorrectable   ---R--   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0x15       GPL,SL  R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    256  Current Device Internal Status Data log
0x25       GPL     R/O    256  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed without error       00%      1342         -
# 2  Short offline       Completed without error       00%      1322         -
# 3  Short offline       Completed without error       00%      1322         -
# 4  Extended offline    Completed without error       00%      1294         -
# 5  Short offline       Completed without error       00%      1274         -
# 6  Short offline       Completed without error       00%      1274         -
# 7  Short offline       Completed without error       00%      1250         -
# 8  Short offline       Completed without error       00%      1250         -
# 9  Short offline       Completed without error       00%      1226         -
#10  Short offline       Completed without error       00%      1226         -
#11  Short offline       Completed without error       00%      1202         -
#12  Short offline       Completed without error       00%      1202         -
#13  Extended offline    Completed without error       00%      1174         -
#14  Short offline       Completed without error       00%      1154         -
#15  Short offline       Completed without error       00%      1154         -
#16  Extended offline    Completed without error       00%      1126         -
#17  Short offline       Completed without error       00%      1106         -
#18  Short offline       Completed without error       00%      1106         -
#19  Short offline       Completed without error       00%      1082         -
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    37 Celsius
Power Cycle Min/Max Temperature:     28/38 Celsius
Lifetime    Min/Max Temperature:     25/38 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    128 (69)
Index    Estimated Time   Temperature Celsius
  70    2019-04-04 21:50    34  ***************
...    ..(  9 skipped).    ..  ***************
  80    2019-04-04 22:00    34  ***************
  81    2019-04-04 22:01    35  ****************
...    ..(  8 skipped).    ..  ****************
  90    2019-04-04 22:10    35  ****************
  91    2019-04-04 22:11    36  *****************
...    ..( 38 skipped).    ..  *****************
   2    2019-04-04 22:50    36  *****************
   3    2019-04-04 22:51    37  ******************
   4    2019-04-04 22:52    37  ******************
   5    2019-04-04 22:53    36  *****************
...    ..(  8 skipped).    ..  *****************
  14    2019-04-04 23:02    36  *****************
  15    2019-04-04 23:03    37  ******************
...    ..(  5 skipped).    ..  ******************
  21    2019-04-04 23:09    37  ******************
  22    2019-04-04 23:10    36  *****************
...    ..(  7 skipped).    ..  *****************
  30    2019-04-04 23:18    36  *****************
  31    2019-04-04 23:19    37  ******************
...    ..(  4 skipped).    ..  ******************
  36    2019-04-04 23:24    37  ******************
  37    2019-04-04 23:25    36  *****************
...    ..(  9 skipped).    ..  *****************
  47    2019-04-04 23:35    36  *****************
  48    2019-04-04 23:36    37  ******************
...    ..(  3 skipped).    ..  ******************
  52    2019-04-04 23:40    37  ******************
  53    2019-04-04 23:41    36  *****************
  61    2019-04-04 23:49    36  *****************
  62    2019-04-04 23:50    37  ******************
  68    2019-04-04 23:56    37  ******************
  69    2019-04-04 23:57    34  ***************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 2) ==
0x01  0x008  4               1  ---  Lifetime Power-On Resets
0x01  0x018  6      3003990427  ---  Logical Sectors Written
0x01  0x020  6        20130657  ---  Number of Write Commands
0x01  0x028  6     12888726656  ---  Logical Sectors Read
0x01  0x030  6        74419798  ---  Number of Read Commands
0x01  0x038  6      4846305500  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4             889  ---  Spindle Motor Power-on Hours
0x03  0x010  4             889  ---  Head Flying Hours
0x03  0x018  4            2953  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4           27924  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              37  ---  Current Temperature
0x05  0x010  1              35  N--  Average Short Term Temperature
0x05  0x018  1              33  N--  Average Long Term Temperature
0x05  0x020  1              38  ---  Highest Temperature
0x05  0x028  1              25  ---  Lowest Temperature
0x05  0x030  1              37  N--  Highest Average Short Term Temperature
0x05  0x038  1              25  N--  Lowest Average Short Term Temperature
0x05  0x040  1              36  N--  Highest Average Long Term Temperature
0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4               0  ---  Number of Hardware Resets
0x06  0x010  4               0  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            1  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            1  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
Chris Moore
PS. Do you have your NAS configured so you can SSH into it with something like PuTTY?
It makes troubleshooting much easier.
mudshark
Ah, HA! I see why a telnet session has it's advantages! Is there a way in the GUI to capture the command text output? In the meantime, looking into SSH
mudshark
The 2 drives I would have questions about are ada1 and ada3. Below their outputs from that smart command:
ADA1
Model Family:     Seagate Constellation ES.2 (SATA 6Gb/s)
Device Model:     ST33000651NS
Serial Number:    Z294F69K
LU WWN Device Id: 5 000c50 04e677d31
Firmware Version: G009
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Size:      512 bytes logical/physical
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Apr 10 15:26:18 2019 EDT
APM feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
See vendor-specific Attribute list for marginal Attributes.
                                        been run.
data collection:                (  600) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        power-saving mode.
recommended polling time:        (   1) minutes.
recommended polling time:        ( 444) minutes.
Conveyance self-test routine
SCT capabilities:              (0x10bd) SCT Status supported.
  1 Raw_Read_Error_Rate     POSR--   075   063   044    -    30192691
  3 Spin_Up_Time            PO----   091   091   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    143
  5 Reallocated_Sector_Ct   PO--CK   100   100   036    -    0
  7 Seek_Error_Rate         POSR--   077   060   030    -    65289153206
  9 Power_On_Hours          -O--CK   058   058   000    -    37612
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   020    -    139
184 End-to-End_Error        -O--CK   097   097   099    NOW  3
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   100   000    -    0
189 High_Fly_Writes         -O-RCK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   068   044   045    Past 32 (0 2 38 27 0)
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    0
192 Power-Off_Retract_Count -O--CK   100   100   000    -    83
193 Load_Cycle_Count        -O--CK   100   100   000    -    741
194 Temperature_Celsius     -O---K   032   056   000    -    32 (0 12 0 0 0)
195 Hardware_ECC_Recovered  -O-RC-   034   003   000    -    30192691
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x08       GPL,SL  R/O      2  Power Conditions log
0xa1       GPL,SL  VS      20  Device vendor specific log
0xa2       GPL     VS    4496  Device vendor specific log
0xa8       GPL,SL  VS     129  Device vendor specific log
0xa9       GPL,SL  VS       1  Device vendor specific log
0xb0       GPL     VS    5176  Device vendor specific log
0xbd       GPL     VS     252  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xd0       GPL,SL  VS       8  Device vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
# 1  Extended offline    Completed without error       00%     37607         -
# 2  Short offline       Completed without error       00%     37548         -
# 3  Extended offline    Completed without error       00%     37535         -
# 4  Extended offline    Completed without error       00%     37438         -
# 5  Short offline       Completed without error       00%     37380         -
# 6  Extended offline    Completed without error       00%     37366         -
# 7  Extended offline    Completed without error       00%     37270         -
# 8  Short offline       Completed without error       00%     37212         -
# 9  Extended offline    Completed without error       00%     37198         -
#10  Extended offline    Completed without error       00%     37102         -
#11  Short offline       Completed without error       00%     37044         -
#12  Extended offline    Completed without error       00%     37034         -
#13  Extended offline    Completed without error       00%     36936         -
#14  Short offline       Completed without error       00%     36876         -
#15  Extended offline    Completed without error       00%     36863         -
#16  Extended offline    Completed without error       00%     36772         -
#17  Short offline       Completed without error       00%     36709         -
#18  Extended offline    Completed without error       00%     36695         -
#19  Extended offline    Completed without error       00%     36600         -
SCT Version (vendor specific):       522 (0x020a)
Current Temperature:                    32 Celsius
Power Cycle Min/Max Temperature:     27/39 Celsius
Lifetime    Min/Max Temperature:     12/58 Celsius
Under/Over Temperature Limit Count:   0/1419
Temperature Logging Interval:        10 minutes
Min/Max recommended Temperature:      0/ 0 Celsius
Min/Max Temperature Limit:            0/ 0 Celsius
Temperature History Size (Index):    128 (38)
  39    2019-04-09 18:10    35  ****************
 ...    ..(  2 skipped).    ..  ****************
  42    2019-04-09 18:40    35  ****************
  43    2019-04-09 18:50    36  *****************
  44    2019-04-09 19:00    37  ******************
  45    2019-04-09 19:10    37  ******************
  46    2019-04-09 19:20    36  *****************
  54    2019-04-09 20:40    36  *****************
  55    2019-04-09 20:50    37  ******************
  56    2019-04-09 21:00    38  *******************
  57    2019-04-09 21:10    38  *******************
  58    2019-04-09 21:20    37  ******************
  59    2019-04-09 21:30    37  ******************
  60    2019-04-09 21:40    37  ******************
  61    2019-04-09 21:50    36  *****************
  62    2019-04-09 22:00    36  *****************
  63    2019-04-09 22:10    35  ****************
  67    2019-04-09 22:50    35  ****************
  68    2019-04-09 23:00    36  *****************
  69    2019-04-09 23:10    36  *****************
  70    2019-04-09 23:20    35  ****************
  71    2019-04-09 23:30    35  ****************
  72    2019-04-09 23:40    35  ****************
  73    2019-04-09 23:50    34  ***************
 ...    ..(  6 skipped).    ..  ***************
  80    2019-04-10 01:00    34  ***************
  81    2019-04-10 01:10    35  ****************
  82    2019-04-10 01:20    35  ****************
  83    2019-04-10 01:30    36  *****************
  84    2019-04-10 01:40    36  *****************
  85    2019-04-10 01:50    35  ****************
  86    2019-04-10 02:00    35  ****************
  87    2019-04-10 02:10    35  ****************
  88    2019-04-10 02:20    36  *****************
  89    2019-04-10 02:30    36  *****************
  90    2019-04-10 02:40    35  ****************
 ...    ..(  6 skipped).    ..  ****************
  97    2019-04-10 03:50    35  ****************
  98    2019-04-10 04:00    34  ***************
  99    2019-04-10 04:10    34  ***************
 100    2019-04-10 04:20    35  ****************
 101    2019-04-10 04:30    35  ****************
 102    2019-04-10 04:40    35  ****************
 103    2019-04-10 04:50    34  ***************
 108    2019-04-10 05:40    34  ***************
 109    2019-04-10 05:50    33  **************
 110    2019-04-10 06:00    33  **************
 111    2019-04-10 06:10    33  **************
 112    2019-04-10 06:20    34  ***************
 113    2019-04-10 06:30    34  ***************
 114    2019-04-10 06:40    34  ***************
 115    2019-04-10 06:50    33  **************
 121    2019-04-10 07:50    33  **************
 122    2019-04-10 08:00    32  *************
 123    2019-04-10 08:10    32  *************
 124    2019-04-10 08:20    33  **************
 125    2019-04-10 08:30    34  ***************
 126    2019-04-10 08:40    33  **************
 127    2019-04-10 08:50    33  **************
   0    2019-04-10 09:00    33  **************
   1    2019-04-10 09:10    32  *************
   5    2019-04-10 09:50    32  *************
   6    2019-04-10 10:00    31  ************
   7    2019-04-10 10:10    31  ************
   8    2019-04-10 10:20    31  ************
   9    2019-04-10 10:30    32  *************
  10    2019-04-10 10:40    32  *************
  11    2019-04-10 10:50    32  *************
  12    2019-04-10 11:00    31  ************
  17    2019-04-10 11:50    31  ************
  18    2019-04-10 12:00    30  ***********
  19    2019-04-10 12:10    30  ***********
  20    2019-04-10 12:20    30  ***********
  21    2019-04-10 12:30    31  ************
  22    2019-04-10 12:40    32  *************
  23    2019-04-10 12:50    31  ************
  26    2019-04-10 13:20    31  ************
  27    2019-04-10 13:30    30  ***********
  28    2019-04-10 13:40    30  ***********
  29    2019-04-10 13:50    30  ***********
  30    2019-04-10 14:00    31  ************
  33    2019-04-10 14:30    31  ************
  34    2019-04-10 14:40    33  **************
  35    2019-04-10 14:50    33  **************
  36    2019-04-10 15:00    32  *************
  37    2019-04-10 15:10    32  *************
  38    2019-04-10 15:20    32  *************
           Read:    100 (10.0 seconds)
          Write:    100 (10.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
0x000a  2            5  Device-to-host register FISes sent due to a COMRESET
ADA3
smartctl -x /dev/ada3
Device Model:     ST33000650NS
Serial Number:    Z294WQXK
LU WWN Device Id: 5 000c50 04ea04362
Add. Product Id:  DELL(tm)
Firmware Version: RA61
Local Time is:    Wed Apr 10 15:28:27 2019 EDT
                                        been run.
data collection:                (  625) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 461) minutes.
recommended polling time:        (   3) minutes.
  1 Raw_Read_Error_Rate     POSR--   078   063   044    -    75622222
  3 Spin_Up_Time            PO----   090   089   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    116
  7 Seek_Error_Rate         POSR--   065   057   030    -    111766945720
  9 Power_On_Hours          -O--CK   095   095   000    -    4972
 12 Power_Cycle_Count       -O--CK   100   100   020    -    102
184 End-to-End_Error        -O--CK   100   100   099    -    0
190 Airflow_Temperature_Cel -O---K   067   054   045    -    33 (Min/Max 28/39)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    58
193 Load_Cycle_Count        -O--CK   100   100   000    -    237
194 Temperature_Celsius     -O---K   033   046   000    -    33 (0 13 0 0 0)
195 Hardware_ECC_Recovered  -O-RC-   025   005   000    -    75622222
240 Head_Flying_Hours       ------   100   253   000    -    4934 (181 57 0)
241 Total_LBAs_Written      ------   100   253   000    -    51536373
242 Total_LBAs_Read         ------   100   253   000    -    2900127627
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
0xa8       GPL,SL  VS      20  Device vendor specific log
0xb0       GPL     VS    5067  Device vendor specific log
0xb6       GPL     VS    1918  Device vendor specific log
No Errors Logged
# 1  Extended offline    Completed without error       00%      4944         -
# 2  Extended offline    Completed without error       00%      4871         -
# 3  Short offline       Completed without error       00%      1331         -
# 4  Short offline       Completed without error       00%      1320         -
# 5  Short offline       Completed without error       00%      1296         -
# 6  Short offline       Completed without error       00%      1272         -
# 7  Extended offline    Completed without error       00%      1261         -
# 8  Short offline       Completed without error       00%      1248         -
# 9  Short offline       Completed without error       00%      1212         -
#10  Short offline       Completed without error       00%      1188         -
#11  Short offline       Completed without error       00%      1164         -
#12  Short offline       Completed without error       00%      1140         -
#13  Short offline       Completed without error       00%      1116         -
#14  Short offline       Completed without error       00%      1092         -
#15  Short offline       Completed without error       00%      1083         -
Current Temperature:                    33 Celsius
Power Cycle Min/Max Temperature:     28/39 Celsius
Lifetime    Min/Max Temperature:     13/46 Celsius
Temperature History Size (Index):    128 (25)
  26    2019-04-09 18:10    36  *****************
 ...    ..(  2 skipped).    ..  *****************
  29    2019-04-09 18:40    36  *****************
  30    2019-04-09 18:50    37  ******************
  31    2019-04-09 19:00    38  *******************
  32    2019-04-09 19:10    37  ******************
 ...    ..(  9 skipped).    ..  ******************
  42    2019-04-09 20:50    37  ******************
  43    2019-04-09 21:00    39  ********************
  44    2019-04-09 21:10    39  ********************
  45    2019-04-09 21:20    38  *******************
  46    2019-04-09 21:30    38  *******************
  47    2019-04-09 21:40    37  ******************
  48    2019-04-09 21:50    37  ******************
  49    2019-04-09 22:00    37  ******************
  50    2019-04-09 22:10    36  *****************
  54    2019-04-09 22:50    36  *****************
  55    2019-04-09 23:00    37  ******************
  56    2019-04-09 23:10    37  ******************
  57    2019-04-09 23:20    37  ******************
  58    2019-04-09 23:30    36  *****************
  59    2019-04-09 23:40    36  *****************
  60    2019-04-09 23:50    35  ****************
  67    2019-04-10 01:00    35  ****************
  68    2019-04-10 01:10    36  *****************
  69    2019-04-10 01:20    36  *****************
  70    2019-04-10 01:30    35  ****************
  74    2019-04-10 02:10    35  ****************
  75    2019-04-10 02:20    36  *****************
  76    2019-04-10 02:30    35  ****************
  77    2019-04-10 02:40    35  ****************
  78    2019-04-10 02:50    34  ***************
  79    2019-04-10 03:00    35  ****************
  83    2019-04-10 03:40    35  ****************
  84    2019-04-10 03:50    34  ***************
  85    2019-04-10 04:00    34  ***************
  86    2019-04-10 04:10    34  ***************
  87    2019-04-10 04:20    36  *****************
  88    2019-04-10 04:30    35  ****************
  89    2019-04-10 04:40    34  ***************
  92    2019-04-10 05:10    34  ***************
  93    2019-04-10 05:20    33  **************
  98    2019-04-10 06:10    33  **************
  99    2019-04-10 06:20    34  ***************
 100    2019-04-10 06:30    34  ***************
 101    2019-04-10 06:40    34  ***************
 102    2019-04-10 06:50    33  **************
 107    2019-04-10 07:40    33  **************
 108    2019-04-10 07:50    32  *************
 109    2019-04-10 08:00    32  *************
 110    2019-04-10 08:10    32  *************
 111    2019-04-10 08:20    33  **************
 112    2019-04-10 08:30    34  ***************
 113    2019-04-10 08:40    33  **************
 114    2019-04-10 08:50    33  **************
 115    2019-04-10 09:00    33  **************
 116    2019-04-10 09:10    32  *************
 123    2019-04-10 10:20    32  *************
 124    2019-04-10 10:30    33  **************
 125    2019-04-10 10:40    33  **************
 126    2019-04-10 10:50    33  **************
 127    2019-04-10 11:00    32  *************
   8    2019-04-10 12:30    32  *************
   9    2019-04-10 12:40    33  **************
  10    2019-04-10 12:50    33  **************
  11    2019-04-10 13:00    32  *************
  20    2019-04-10 14:30    32  *************
  21    2019-04-10 14:40    33  **************
  22    2019-04-10 14:50    34  ***************
  23    2019-04-10 15:00    33  **************
  24    2019-04-10 15:10    33  **************
  25    2019-04-10 15:20    33  **************
           Read:     80 (8.0 seconds)
          Write:     80 (8.0 seconds)
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
mudshark
OMG. Lifesaver. (No, I'm not predisposed to hyperbole or anything.)
Chris Moore
I don't think there is.
It looks like you have this straightened out. Just be sure to add the replacement disk back into the list of disks to run SMART tests against. When you do a disk replacement, the new drive is not automatically added into that.
Also, for next time, because those are some old disks and next time could be soon, here is the troubleshooting guide:
Hard Drive Troubleshooting Guide (All Versions of FreeNAS)
https://forums.freenas.org/index.ph...bleshooting-guide-all-versions-of-freenas.17/
Speaking of old disks, I have a server at work that is still rocking some 6.2 year old drives, but it is generally a good idea to replace drives around the five year mark because they are somewhat more likely to fail after that point.
