Hi -
I was looking at adding a NAS to my network to store photos, videos, my music library and other miscellaneous documents. Currently,
this is around a little over a terabyte, but I see it growing in the near future with photos and HD videos of my little ones.
I had looked at commercial solutions but then had seen mention of FreeNAS, and being a tinkerer I liked the idea of building
a NAS myself.
After looking around I was thinking of using the following hardware:
https://pcpartpicker.com/list/ccq2jc
Here are my questions:
1) Does the hardware seem a good selection or should I be considering something else? I have heard that some of the SilverStone cases
have had some overheating issues, but that those can be overcome by drilling some ventilation holes. I am pretty open to most anything,
but I would like to keep the cost from climbing much higher.
2) Is RAIDZ1 the recommended configuration I should be using in this scenario? I would like to not have to commit to buying all of
my drives now but have the option to add more later. This is the reason I chose the case I did, since it has 8 bays. Is it reasonable
to plan to add 4 drives now in RAIDZ1 and then in a few years, add 4 more? Reading the documentation it appears at that point I would
need to add a new VDEV to the pool with the new drives at which point they would be striped with the four existing? Am i understanding
this correctly? Would I be better off just adding all the drives up front? Would the new drives need to be the same size as the existing
VDEV's drives?
3) Is it recommended to use multiple NICs via aggregation to improve performance?
4) I have seen some comments about not using mini-ITX. Is this just due to the compact nature, the cost, or something else?
Thanks in advance.
a NAS myself.
VDEV's drives?
Thanks in advance.
