slayer99199
- Oct 5, 2017
I should note that despite this error, my system boots and is otherwise running normally. Should I just ignore this or is this a problem?
OS Version:
FreeNAS-11.2-U4.1
(Build Date: May 10, 2019 21:33)
Processor:
Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz (4 cores)
Memory:
16 GiB
Motherboard:
ASRock C236 WSI
I have 8 disks in 2 pools connected to 8 SATA slots on my motherboard (I don't have an external SATA card...yet). So my boot drive is actually a 256GB SSD connected via a SATA-to-USB connector and from there to the on board internal USB (you can see it to the right of the SATA ports in this image):
The error:
SanDisk is where I store my configuration backups.
OS Version:
FreeNAS-11.2-U4.1
Processor:
Memory:
16 GiB
Motherboard:
ASRock C236 WSI
The error:
VT(efifb): resolution 800x600 CPU: Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz (3792.15-MHz K8-class CPU) Structured Extended Features3=0xc000000<IBPB,STIBP> avail memory = 16226922496 (15475 MB) Timecounter "TSC-low" frequency 1896073183 Hz quality 1000 pcib0: _OSC returned error 0x10 orm0: <ISA Option ROM> at iomem 0xc0000-0xcffff on isa0 ugen0.2: <SanDisk Ultra Fit> at usbus0 umass0: <SanDisk Ultra Fit, class 0/0, rev 2.10/1.00, addr 1> on usbus0 ugen0.3: <SABRENT SABRENT> at usbus0 umass1: <SABRENT SABRENT, class 0/0, rev 3.10/a0.00, addr 2> on usbus0 (probe0:umass-sim1:1:0:0): REPORT LUNS. CDB: a0 00 00 00 00 00 00 00 00 10 00 00 (probe0:umass-sim1:1:0:0): CAM status: SCSI Status Error (probe0:umass-sim1:1:0:0): SCSI status: Check Condition (probe0:umass-sim1:1:0:0): SCSI sense: ILLEGAL REQUEST asc:20,0 (Invalid command operation code) (probe0:umass-sim1:1:0:0): Error 22, Unretryable error da1 at umass-sim1 bus 1 scbus10 target 0 lun 0 da1: < SABRENT 2210> Fixed Direct Access SPC-4 SCSI device da1: Serial Number 000000123AD2 da1: 400.000MB/s transfers da1: 238475MB (488397168 512 byte sectors) da1: quirks=0x2<NO_6_BYTE> epair0a: Ethernet address: 02:e4:d0:00:05:0a epair0b: Ethernet address: 02:e4:d0:00:06:0b
