System always reboot when it scan dataset
RICE
Hi all,
My machine have been work about one year without any critical issue. But this night I reboot it only , the system always reboot when scanned dataset.
I press "Ctrl+c" to stop to scan, system can let me login the web (I know it is helpless). But about 10 seconds ago, system also reboot.
Is any ideas can let me try to fix this issue? I have no idea after searching the web.
Thanks.
RICE
[Fix]
orig: I press "Ctrl+c" to stop to scan, system can let me login the web
mod: I press "Ctrl+c" to stop scanning, system can let me login the web
Alecmascot
I think we need full details of your system please.
What action has initiated the dataset scan ?
RICE
I think you mean the machine info~
Freenas 11.3-U5
RAM: 64GB
Cache: 512GB Nvme
Storage: 4TB*8 in RaidZ2
RICE
Please refer attach files, I capture part of log before the system reboot.
According to the log, I guess system try to scan plug-in(TRANSMISSION) dataset but it get incorrect response.
After re-trying a few times, system still get error.
Finally, it reboot over and over.
Alecmascot
Freenas 11.3-U5
RAM: 64GB
Cache: 512GB Nvme
I do not think that meets the forum requirement to disclose the full hardware/software configuration.....
