Ok then:
[root@daniel] ~# /usr/sbin/syslogd -s -C -d
syslogd: bind: Address already in use
logmsg: pri 53, flags 4, from , msg syslogd: bind: Address already in use
Logging to CONSOLE /dev/console
can't open /dev/klog (16)
off & running....
init
cfline("*.err;kern.warning;auth.notice;mail.crit /dev/console", f, "*", "*")
cfline("*.notice;authpriv.none;kern.debug;lpr.info;mail.crit;news.err /var/log/messages", f, "*", "*")
cfline("security.* /var/log/security", f, "*", "*")
cfline("auth.info;authpriv.info /var/log/auth.log", f, "*", "*")
cfline("mail.info /var/log/maillog", f, "*", "*")
cfline("lpr.info /var/log/lpd-errs", f, "*", "*")
cfline("ftp.info /var/log/xferlog", f, "*", "*")
cfline("cron.* /var/log/cron", f, "*", "*")
cfline("*.emerg *", f, "*", "*")
cfline("*.* /var/log/ppp.log", f, "ppp", "*")
4 3 2 3 5 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 X CONSOLE: /dev/console
7 5 2 5 5 5 6 3 5 5 X 5 5 5 5 5 5 5 5 5 5 5 5 5 X FILE: /var/log/messages
X X X X X X X X X X X X X 7 X X X X X X X X X X X FILE: /var/log/security
X X X X 6 X X X X X 6 X X X X X X X X X X X X X X FILE: /var/log/auth.log
X X 6 X X X X X X X X X X X X X X X X X X X X X X FILE: /var/log/maillog
X X X X X X 6 X X X X X X X X X X X X X X X X X X FILE: /var/log/lpd-errs
X X X X X X X X X X X 6 X X X X X X X X X X X X X FILE: /var/log/xferlog
X X X X X X X X X 7 X X X X X X X X X X X X X X X FILE: /var/log/cron
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 X WALL:
7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 X FILE: /var/log/ppp.log (ppp)
logmsg: pri 56, flags 4, from daniel, msg syslogd: restart
syslogd: restarted
logmsg: pri 6, flags 4, from daniel, msg syslogd: kernel boot file is /boot/kernel/kernel
Logging to FILE /var/log/messages
^Csyslogd: exiting on signal 2
logmsg: pri 53, flags 4, from daniel, msg syslogd: exiting on signal 2
[root@daniel] ~#
And the more verbose one:
[root@daniel] ~# /usr/sbin/syslogd -s -C -d -v
off & running....
init
syslogd: restarted
[root@daniel] ~#
(looks the same to me though)
It says "can't open /dev/klog (16)". What does that mean?
Regards,
Memel
