I am trying to setup the Deluge app with OpenVPN from TrueCharts.
OpenVPN is failing after trying to create the IPv6 tunnel:
To try and resolve this I've added:
into System Settings > Advanced > Sysctl
This seems to have applied OK:
This post suggests all kernel sysctl settings will be applied inside pods but that doesn't seem to be the case, IPv6 is still disabled inside the pod:
Initially I thought disabling IPv6 in the kernel would resolve the problem as I found some suggestions of this in some other threads, but it didn't seem to help, and then I found it was disabled inside the pods anyway.
If anyone can help me set this sysctl setting inside the pod or might know another reason why OpenVPN won't work inside this app please let me know.
2023-03-25 17:13:19.387938+00:00+ exec sg vpn -c 'openvpn --cd /vpn --config /vpn/vpn.conf --script-security 2 --redirect-gateway def1 --auth-user-pass /vpn/vpn.auth ' 2023-03-25 17:13:19.389416+00:00Sat Mar 25 17:13:19 2023 OpenVPN 2.4.9 x86_64-alpine-linux-musl [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Apr 20 2020 2023-03-25 17:13:19.389450+00:00Sat Mar 25 17:13:19 2023 library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.10 2023-03-25 17:13:19.442684+00:00Sat Mar 25 17:13:19 2023 TCP/UDP: Preserving recently used remote address: [AF_INET]<IPv4 ADDRESS>:443 2023-03-25 17:13:19.442726+00:00Sat Mar 25 17:13:19 2023 UDP link local: (not bound) 2023-03-25 17:13:19.442736+00:00Sat Mar 25 17:13:19 2023 UDP link remote: [AF_INET]<IPv4 ADDRESS>:443 2023-03-25 17:13:19.479697+00:00Sat Mar 25 17:13:19 2023 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this 2023-03-25 17:13:19.647620+00:00Sat Mar 25 17:13:19 2023 [bviserver] Peer Connection Initiated with [AF_INET]<IPv4 ADDRESS>:443 2023-03-25 17:13:20.888565+00:00Sat Mar 25 17:13:20 2023 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:1: block-outside-dns (2.4.9) 2023-03-25 17:13:20.888823+00:00Sat Mar 25 17:13:20 2023 TUN/TAP device tun0 opened 2023-03-25 17:13:20.888875+00:00Sat Mar 25 17:13:20 2023 /sbin/ip link set dev tun0 up mtu 1500 2023-03-25 17:13:20.889648+00:00Sat Mar 25 17:13:20 2023 /sbin/ip addr add dev tun0 172.16.0.85/24 broadcast 172.16.0.255 2023-03-25 17:13:20.890497+00:00Sat Mar 25 17:13:20 2023 /sbin/ip -6 addr add <IPV6 ADDRESS>/64 dev tun0 2023-03-25 17:13:20.890961+00:00RTNETLINK answers: Permission denied 2023-03-25 17:13:20.890994+00:00Sat Mar 25 17:13:20 2023 Linux ip -6 addr add failed: external program exited with error status: 2 2023-03-25 17:13:20.891015+00:00Sat Mar 25 17:13:20 2023 Exiting due to fatal error
net.ipv6.conf.all.disable_ipv6=0
root@bocchi[~]# sysctl net.ipv6.conf.all.disable_ipv6 net.ipv6.conf.all.disable_ipv6 = 0 root@bocchi[~]# sysctl net.ipv6.conf.default.disable_ipv6 net.ipv6.conf.default.disable_ipv6 = 0 root@bocchi[~]# sysctl net.ipv6.conf.lo.disable_ipv6 net.ipv6.conf.lo.disable_ipv6 = 0
root@deluge-56c95cdfb8-jn9q4:/# sysctl net.ipv6.conf.all.disable_ipv6 net.ipv6.conf.all.disable_ipv6 = 1
