salman8506
- Dec 6, 2021
I have an issue with my current x370 board and having a b450 lying around but is 1 sata port short. If I install the new board will the boot drive which was earlier working on sata work using USB adapter ? Or I will have to perform a reinstall. Only reason I am concerned is i have few vms and plugins with custom setting that would need to be rebuild consuming a lot of time. Any suggestions appreciated.
Edit1:- another option I have is to use 1:4 sata multiplexer but that would divide 1 port bandwidth between 4 drives and one data drive will have to be attached to this card. This might not work, if works the last data drive will be slower then the remaining 5 drives.
