Erik Carlson
- Aug 2, 2012
I was a happy user of 8.0.4 on an HP microserver N40L with 8 GB RAM, 2 x 1GB hard disks (mirrored) and 1 x 3TB hard disk (not mirrored), boot drive is a 32GB USB key not that that's probably relevant.
I upgraded to 8.2.0p1 the weekend after it has been released, however I have had problems since.
I upgraded using the boot CD method. After upgrade all looked well. I installed the plugins jail really out of curiosity, i tried to install firefly which was answered by "an error occured" in the GUI , i couldn't get past this and didn't really care so I disabled plugins.
I have enabled autotune. I have AFP, CIFS, SMART monitoring and SSH on, everything else is off.
Under 8.0.4 i almost never saw any swap usage at all. Under 8.2.0 I don't need to be doing anything and several GB of swap can be in use, and the big problem is that under modest load, (rebuilding a 300GB file on the 3TB volume) the swap usage rises and after 30 mins to 1hour the system slows down. web access stops , file server is reported as having closed down by the clients and eventually all i can do is reboot from the console.
The logs show things like
+swap_pager_getswapspace(16): failed
+swap_pager_getswapspace(12): failed
+swap_pager_getswapspace(6): failed
+swap_pager_getswapspace(9): failed
+swap_pager_getswapspace(5): failed
+pid 15623 (smbd), uid 1001, was killed: out of swap space
+swap_pager_getswapspace(8): failed
I don't think this has been reported elsewhere, i've looked!
I backed up my 8.0.4 settings and i think rollback to 8.0.4 is as simple as reinstall onto the stick and reimport of settings right?, so this is what I plan to do soon if I cannot solve the problem.
Does anybody have any ideas?
Thank you in advance.
Erik Carlson
Erik Carlson
