Hi all!
running a FREENAS 11.2-RC1 box with:
MOBO: Asrock mini-itx E3C226D2I
CPU: Intel E3-1225 v3 @ 3.20GHz
HDD: 5x 3TB WD30EFRX RED (RAIDZ2 setup)
RAM: 2x8GB kingston KVR16LE11L/8 ECC 1,35v
This morning, i found the "daily security run output" mail full of this:
I searched on the forum and it should be about a memory leak, but actually, apart from plex and trasmission, I don't have other plugins on.
https://ibb.co/jCgDX0
The graphs (especially the ones from the old webUI), reports swap increase from 03:00am till 8:20am, but i don't remember to have any task set at that time (scrub of data pool starts on 01.00am and not that day, and scrub of USB start at 03.45).
How can i understand what caused the problem?
freenas.local kernel log messages: > swap_pager_getswapspace(3): failed > swap_pager_getswapspace(3): failed > swap_pager_getswapspace(7): failed > swap_pager_getswapspace(4): failed > swap_pager_getswapspace(6): failed > swap_pager_getswapspace(3): failed > swap_pager_getswapspace(12): failed > swap_pager_getswapspace(3): failed > swap_pager_getswapspace(3): failed > swap_pager_getswapspace(9): failed > swap_pager_getswapspace(3): failed > swap_pager_getswapspace(5): failed
