MarioDespot
Member
- Jan 20, 2016
As i told before i tried that. Results are same!!!!!!!
This is after upgrade to the last version of p20
sas2flash -listall
LSI Corporation SAS2 Flash Utility
Version 16.00.00.00 (2013.03.01)
Copyright (c) 2008-2013 LSI Corporation. All rights reserved
Adapter Selected is a LSI SAS: SAS2008(B2)
Num Ctlr FW Ver NVDATA x86-BIOS PCI Addr
0 SAS2008(B2) 20.00.04.00 14.01.00.08 No Image 00:20:00:00
Finished Processing Commands Successfully.
Exiting SAS2Flash.
[root@freenas] ~# camcontrol devlist
<LENOVO-X ST900MM0006 L56Q> at scbus1 target 1 lun 0 (pass0,da0)
<IBM-ESXS AL13SEB900 SB35> at scbus1 target 2 lun 0 (pass1,da1)
<IBM-ESXS HUC109090CSS60 J2EH> at scbus1 target 3 lun 0 (pass2,da2)
<LENOVO-X ST900MM0006 L56Q> at scbus1 target 4 lun 0 (pass3,da3)
<LENOVO-X ST900MM0006 L56Q> at scbus1 target 10 lun 0 (pass4,da4)
<LENOVO-X ST900MM0006 L56Q> at scbus1 target 11 lun 0 (pass5,da5)
<Kingston DataTraveler 3.0 PMAP> at scbus3 target 0 lun 0 (pass6,da6)
[root@freenas] ~# camcontrol identify da0
camcontrol: ATA ATAPI_IDENTIFY via pass_16 failed
[root@freenas] ~# camcontrol identify da1
[root@freenas] ~# camcontrol identify da2
[root@freenas] ~# camcontrol identify da3
[root@freenas] ~# camcontrol identify da4
[root@freenas] ~# camcontrol identify da5
[root@freenas] ~# gpart show
=> 34 30277565 da6 GPT (14G)
34 8190 - free - (4M)
8224 1024 1 bios-boot (512k)
9248 30268344 2 freebsd-zfs (14G)
30277592 7 - free - (3.5k)
=> 34 1758174701 da2 GPT (838G) [CORRUPT]
34 4062 - free - (2M)
4096 4194304 1 freebsd-swap (2.0G)
4198400 1753972736 2 freebsd-zfs (836G)
1758171136 3599 - free - (1.8M)
=> 34 1758174701 da4 GPT (838G) [CORRUPT]
=> 34 1758174701 da5 GPT (838G) [CORRUPT]
=> 34 1758174701 da0 GPT (838G)
34 1758174701 - free - (838G)
=> 34 1758174701 da1 GPT (838G)
[root@freenas] ~# zpool create test da0
cannot create 'test': no such pool or dataset
[root@freenas] ~# zpool create test /dev/da0
[root@freenas] ~# zpool create test /dev/da1
[root@freenas] ~# zpool status
pool: freenas-boot
state: ONLINE
status: One or more devices are configured to use a non-native block size.
Expect reduced performance.
action: Replace affected devices with devices that support the
configured block size, or migrate data to a properly configured
pool.
scan: none requested
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
gptid/fa17a121-b86c-11e5-973e-40f2e9df0d5a ONLINE 0 0 0 block size: 8192B configured, 8388608B native
sas2flash -listall
Exiting SAS2Flash.
pool: freenas-boot
state: ONLINE
pool.
