friolator
- Jun 9, 2016
We work with very large file sets. Very large. Mostly image sequences of feature films at 4k resolution, so somewhere on the order of 120,000 files per movie, topping out at about 5TB. Currently we've got 12TB or larger RAIDs in each of our film scanners, in our color correction systems and in our restoration system. We sneakernet files around, using 6TB bare drives and hot-swap drive docks. It works, but it's inefficient and slow.
We have a 16-drive FreeNAS system set up now, which is connected over 1GbE, but we can only really use it for smaller projects. It acts as a long term parking location for files before they go to more permanent LTO tape backups. I like FreeNAS though, so I'd like to use it for our SAN.
I just bought a 16port 40GbE switch. The thinking is we'll scan a film directly to the SAN (iSCSI), unmount the iSCSI target, mount it from the grading system and write the output back over the network to another iSCSI target. That then gets mounted on the restoration system, if necessary, and we do the same thing. So the plan is to have maybe 60-70TB of storage broken up into 6TB chunks. That should allow us to work on at least 3 jobs at once without having to worry about shuffling files around to make space.
I have an empty 20-bay server enclosure in addition to our existing 16-bay, and a third enclosure with another 8 bays. The plan is to use the 20bay machine with three cards installed:
1) 40GbE NIC to connect to the switch (dual-port?)
2) 24-port LSI SAS card for the 20 drives in the enclosure
3) 24-port LSI SAS card for the two other enclosures, which we'll add to as we need to expand.
So my initial question is: What's FreeNAS support for 40GbE like? Are there specific cards we should be looking at?
