SuperMicro X10SL7-F
Sir.Robin
I upgraded to BIOS v1.10. When you enable powerd, do you see the xeon properly scaling down, or is it always at 3300/3100?
So, with powerd disabled:
NAS01] /# sysctl dev.cpu.0.freq
dev.cpu.0.freq: 3101
With powerd enabled:
@NAS01] /# sysctl dev.cpu.0.freq
dev.cpu.0.freq: 3100
[warlock@NAS01] /# sysctl dev.cpu.0.freq
dev.cpu.0.freq: 2300
dev.cpu.0.freq: 1900
dev.cpu.0.freq: 1800
dev.cpu.0.freq: 1600
dev.cpu.0.freq: 1500
dev.cpu.0.freq: 1100
dev.cpu.0.freq: 1000
dev.cpu.0.freq: 875
dev.cpu.0.freq: 800
dev.cpu.0.freq: 700
dev.cpu.0.freq: 500
dev.cpu.0.freq: 400
dev.cpu.0.freq: 300
dev.cpu.0.freq: 200
dev.cpu.0.freq: 100
I guess throttling works :)
Sir.Robin
So, i did replacement + installed fresh FreeNAS 9.1.1
- I have also C1, but i don't care about USB3 -> disabled in BIOS
- BIOS updated to R 1.10 (19.7.2013)
- LSI flashed into IT mode
- ZPOOL autoimported without issues, BUT i am missing serial number for one disk o_O
da0 - da5 ... all of them are same WD green model, same size, in one RAIDZ2 pool, all of them connected into LSI controller. da0 is plugged into port0, da1 into port1, ... etc
ada0 ... just UFS disk, plugged into standard SATAIII port.
Any clue why i am missing one serial?
When running freenas on this board directly (bare metal/no hypervisor) I too am missing the da0 serial.
But when running ESXi 5.5 and passthrough, i get all serials o_O
HolyK
Ninja Turtle
Well, the info is not in the db at all ... o_O
sqlite> select * from storage_disk;
1|Disabled|60|||{devicename}da0|1|Disabled|Auto||bay4||1|da0
1|Disabled|60|WD-WMC1XXXXXXXX||{serial}WD-WMC1XXXXXXXX|1|Disabled|Auto||bay3||4|da1
1|Disabled|60|WD-WMC1XXXXXXXX||{serial}WD-WMC1XXXXXXXX|1|Disabled|Auto||bay2||5|da2
1|Disabled|60|WD-WMC1XXXXXXXX||{serial}WD-WMC1XXXXXXXX|1|Disabled|Auto||bay1||6|da3
1|Disabled|60|WD-WMC1XXXXXXXX||{serial}WD-WMC1XXXXXXXX|1|Disabled|Auto||bay6||7|da4
1|Disabled|60|WD-WMC1XXXXXXXX||{serial}WD-WMC1XXXXXXXX|1|Disabled|Auto||bay5||8|da5
Okey Grak
dev.cpu.0.freq: 875
dev.cpu.0.freq: 800
dev.cpu.0.freq: 700
dev.cpu.0.freq: 500
dev.cpu.0.freq: 400
dev.cpu.0.freq: 300
dev.cpu.0.freq: 200
dev.cpu.0.freq: 100
Weird. Upon boot with powerd enabled, my throttling does not work. If I disable, then re-enable powerd, the throttling begins to happen. Do you mind seeing if you can reproduce the same behavior?Maybe it is a haswell issue.. If not I might re-install as I've been playing around with powerd to try fixing it, not knowing simple restart would do the trick.
HolyK
Ninja Turtle
2 Okey Grak: I can confirm your observations. Intel i3-4130
Powerd was enabled before last reboot => throttling does not work
[root@HolyNAS] /mnt# sysctl dev.cpu.0.freq
dev.cpu.0.freq: 3400
Disable/Enable powerd => will make throttling work
dev.cpu.0.freq: 2700
dev.cpu.0.freq: 2200
dev.cpu.0.freq: 1300
dev.cpu.0.freq: 875
dev.cpu.0.freq: 400
dev.cpu.0.freq: 200
raidflex
I can confirm the same thing with powerd. It will work if you reboot with it disabled and then enable it after the reboot.
Sir.Robin
Sir.Robin: Very nice. Thank you! :)
Just interest: For what do you virtualize the server?
No problem!
The plan were to be able to use my box for more than just nas. With vsphere i can do a bit lab/testing aswell :)
Sent from my iPhone using Tapatalk - now Free
Okey Grak
I'm also seeing really weird power behavior with this setup. I'm consuming at 40-45W at the plug, and it makes no difference if powerd is enabled or disabled. dev.cpu.0.freq showing 200mhz or 3300mhz makes no difference in power consumption. I wonder if the CPU is doing proper voltage reduction?
I have only one SSD hooked up to the box, and 32GB of ECC ram, and a platinum rated PSU. Seems quite high for idle.
Okey Grak
IPMI is reporting a VCORE of 1.83V with or without scaling. I'm wondering if there is a either a BIOS bug or FreeBSD issue not allowing these haswell chips to fully scale down.
jgreco
Resident Grinch
That's similar to our Sandy's. powerd isn't that helpful on modern gear, it was meant for older (early- to mid-2000's) gear that didn't idle efficiently but would get fairly efficient if you dropped clock speed.
jonnn
Thanks for the info. That is disappointing.
I have been testing FreeNAS/ZFS on this temporary setup:
Cheap ass MSI H61 motherboard with 4x SATA ports
Pentium-Class IVY-Bridge CPU
2GB of random cheap ram
4x 7200 RPM Toshiba drives in RAIDZ2
Terrible 600W cheap ass PSU (probably rated 60+ Wood)
With all the drives spun down, I get about 31-32 W at idle. With no drives (similar to your setup) it's like 27-28W
You do have much more ram, but my experience shows ram doesn't draw much?
Try underclocking the CPU in the BIOS.
I set my max multiplier from 25x to 20x and saw a power drop at idle. Performance wasn't noticeably affected... still get like 550 MB/s on scrubs, 90+MB/s on network transfers and good rebuild speeds.
jonnn
I did forget that this board has an LSI controller integrated. That could account for the difference. :smile:
RAM typically uses a whopping 1-2w per stick, tops. What I find hilarious is that the "low power" DDR3 sticks only save a fraction of a watt... per stick. In fact, when I experimented with them in the lab, I couldn't even actually prove solidly that wattage was lower because CPU usage is not actually constant. Even in DOS 6.22 the power usage fluctuated.
jyavenard
is powerd disabled by default in FreeNAS?
having said that; i've always been a bit suspicious of userland daemon managing what should be real time (or close to) feature...
IMHO there are better ways to control power usage than throttling the CPU frequencies. That was fine back in the days, but with features like C-state they are more efficient way to do things
not sure how much of FreeNAS let you tweak; but this page may be relevant:
https://wiki.freebsd.org/TuningPowerConsumption
jyavenard
see comment 91
thanks... I only saw it after I replied and continued on reading other messages.
would be interesting to boot that box under linux and check power usage there. Linux has always been a bit ahead than FreeBSD when it comes to hardware support.
Posttime
Yeah maybe. But it restricts my options. And SM have been acting like a bunch of assholes about this so I'm disinclined to give them my business, or that of my company, for a bunch of their shiny new x10 boards.
According to SM:
FYI, this is how they suggest how to pick out a C2 stepping board:
The board serial number has year and month manufactured information after​
first two letters.​
For example, ZM 137S99999​
That means board has been manufactured on July 2013.​
If you get a board for September or later, then it should be using C2 chipset.​
To be 100% certain, you would have to check with CPU-Z or in BIOS after powering up board though.​
A little late to the party on this...however I just picked up a X10slh-f board two weeks ago and it was a ZM 138S9999999 board so I figured I need to RMA it. Contacted tech support and they were not able to tell me for sure if it is C1 or C2. Didn't have my CPU yet so I just RMA'd the board on crossship as I understood "ZM13S"... was the magic number. So the new board I get is...ZM138S9999999. Contact the RMA dept and my contact there HUY (great guy by the way) assures me that te new board is C2 and that it was bench confirmed prior to leaving. My Cpu turns up a couple days later, I test both boards, both are C2.:( $30 down the drain to return the board I thought would be C1 stepping. Not all ZM138 boards are C2 though, however anything being added to supplier stock now is so if your local shop was backordered you should be getting C2 board exclusively on 138 numbers....at least on the X10SLH-F.[/quote]
Sir.Robin
Yeh... i think you stress too much with the C1 vs C2 thang... it's a server... who gives a flyin' f*** bout sleepmode? :p
