That would depend on your UPS. But unless your batteries are old or you're using too small a UPS it should give you at least 5 minutes at full load - and shutting down shouldn't be full load.
Sent from my GT-I9300 using Tapatalk 4
?Just been reading about performance when doing a zfs destroy. Looks like you might be able to shutdown in the middle of it at the expense of a "slow" restart. How slow I don't know, the length of the destroy maybe? If so, hibernation might sound a better idea?
i
What does this have to do with the X0SL7-F? Did you post to the wrong thread?
I'm still confused. zfs destroy deletes your zpool. What does a zfs destroy have to do with USB or hibernation? I can't imagine that in the few seconds it takes to destroy a zpool you'd go into hibernation....Nope. If you're going to use a usb3 flash drive (as vegaman does) but need to hibernate you probably (Intel's not clear on exactly when reenumeration breaks) need the c2 stepping.
Nope. Destroying a pool takes just a few seconds. Basically the pool is unmounted, then the partition deleted. I've destroyed 30TB+ pools in seconds.I'm reading that a zfs destroy can take hours or days in the worst case. Is this not true?
You're right for snapshots. zfs destroy can destroy file systems too though.Not a zpool destroy, a zfs destroy. Maybe specifically of a snapshot?
Hmm. Let me have a think about that. (Wearing my other hat I'm also putting together a non-NAS server which will use zfs under linux and 16GB ramdisks which need saving on a power outage for which an orderly shutdown of the software is not an option in the duration of even a good ups battery.)You're right for snapshots. zfs destroy can destroy file systems too though.
zfs destroy can, in theory, take a VERY VERY long time(hours/days). But we'd be talking very very very large pools that are very very very busy with extremely big snapshots. I've deleted 1TB snapshots in 20-30 seconds. We'd probably be talking 100TB+ pools easily and the snapshot being deleted was a majority of the pool.
zfs v5000 is supposed to eventually have the feature so that it works in the background and cleans up your zpool when you delete a snapshot. But it hasn't been implemented yet.
As for hibernation, so much hardware doesn't like hibernation I'd never recommend it for a server under any circumstances. Far better for reliability of the server and the services it depends on and serves to do a shutdown. Besides, if you are talking about a pool big enough for a snapshot being deleted to affect a shutdown significantly, you'd also be talking about a server with 100s of GB of RAM. And saving that to disk for hibernation is far less feasible than doing a server shutdown.
Besides, for your average server, what's the likelihood you'd happen to be deleting a snapshot at the moment of power loss. I'm sure it happens, but its far more likely the server will be idle.
Hi raidflex.Well I changed the IP of the IPMI firmware again, hopefully it will stick this time. Seems to have fixed the problem for now.
So far it is working without issues aside from the IP problem, which seems to be fixed since I last change the IPMI IP. I already had the LSI HBA from my previous build and I have 8 HDDs so I figured I would keep it the same and then add additional drives using the on-board controller. I have about 6 different plugins, including Plex running on the system and it runs very smooth.Hi raidflex.
How are you finding the x10sl7-f? Apart from the ipmi/lan port issue any other problems?
How come you went for the LSI card rather than reflashing the onboard?
i
Awesome, you will enjoy the board!My X10SL7 is on the way! Even got it cheaper than the X10SLH sells for here in Norway :D
