Ziferius, I'm getting some strange results from one of the modules I got from Superbiiz back in March (see below).
I ran Memtest86+ 5.01 for 17 hours on the default settings and it found no errors. However, when I looked at the Event Logs in the BIOS it showed (see below). I've only had the machine powered on fewer than 10 times (on for only 1 - 5 hours each time, except for the 17 hour memtest) since I put it together. Is this normal, or is DIMMA1 faulty?
DATE: | TIME: | ERROR CODE: | SEVERITY: | DESCRIPTION:
05/05/14 | 01:20:30 | Smbios 0x01 | DIMMA1 | Single Bit ECC Memory Error
05/05/14 | 03:08:27 | Smbios 0x01 | DIMMA1 | Single Bit ECC Memory Error
05/05/14 | 06:48:06 | Smbios 0x01 | DIMMA1 | Single Bit ECC Memory Error
05/05/14 | 09:34:40 | Smbios 0x01 | DIMMA1 | Single Bit ECC Memory Error
05/18/14 | 11:48:03 | Smbios 0x01 | DIMMA1 | Single Bit ECC Memory Error
06/15/14 | 11:32:58 | Smbios 0x01 | DIMMA1 | Single Bit ECC Memory Error
06/22/14 | 15:21:03 | Smbios 0x01 | DIMMA1 | Single Bit ECC Memory Error
Samsung DDR3-1600 ECC CL11
Mfr Part Number: M391B1G73QH0-YK0
