ALFA
- Aug 23, 2014
Hi fellas, good day.
Have a doubt about this chassis and is if it could accommodate any x10 supermicro motherboard inside of it, anyone have made this any try to stuff it with some new juice motherboard beside the x8 Models, there is any way to modified it to be compatible with the x10?. Its because a found it in Ebay with a brainless price and I already have this motherboard. Any suggestion please? it would be greatful, and many thanks in advanced.
the link to the chassis: http://www.supermicro.com/products/chassis/4U/846/SC846E16-R1200.cfm
the link to the x8 motherboard that accept: http://www.supermicro.com/products/motherboard/QPI/5500/X8DT6-F.cfm?IPMI=Y&SAS=N
the link to the x10 motherboard that I have: http://www.supermicro.com/products/motherboard/Xeon/C600/X10DRD-iNT.cfm
Pd. I saw this in one of the note in the X10DRD-iNT motherboard page "To support the new generation Intel® Xeon® processor-based motherboards, Revision M chassis is recommended". Anyone know what its need it the Revision M, what they change in the chassis so it could work with the new E5-XXXX processors?
Kind regards
Kind regards
