VladTepes
- May 18, 2016
Issue 1
I have just two plugins currently. These were installed directly via the GUI.
When I go into 'plugins - installed' the system takes well over a minute to tell me that I have those two plugins...
Currently plex is turned on, and has an icon next to it.
Emby is off and there is simply a placeholder, not a proper icon..
If I try to turn emby on, I get that little progress bar beside the server status which goes for several minutes then stops. Emby is still off afterward.
Issue 2
If I go to 'plugins - available' it says loading and ultimately 'no entry has been found' ?
For the sake of clarity the 'plugins-configuration' still ha sthe repository URL at the default http://download.freenas.org/plugins/9/x64/pbi-meta/pbi-repo.rpo
If anyone can steer me it the right direction to solving things, that'd be super :) Cheers
Plugin name Version PBI Jail Service status Actions Plexmediaserver 1.8.4.4249 plexmediaserver-1.8.4.4249-amd64 plexmediaserver_1 Emby 3.2.30.0 emby-3.2.30.0-amd64 emby_1
Issue 2
