Suggestion about new drive for upgrade
vatastala
Hi all,
I'd like to have a suggestion about a possible upgrade on my NAS composed by 6x3TB disks...At the moment, I have a failed disk and I have the possibility to give It back to the seller a choose a new one.
My question is...Make sense to take a 1x4TB disk for future upgrade for my NAS? I would like to have much storage, but I don't know If It is convenient to start to buy new units with more space...I mean, at the moment ( till I will upgrade all disks to 4TB ) the system will use only 3 of 4TB of the new unit, isn't It? Also, at the moment I don't have external storage to move data temporarily from my pool.
If you have any suggestion about the best practice for this kind of purposes will be appreciated :smile:
Arubial1229
If you replace the 3TB with a 4TB, the system will only use 3 of the 4TB on the new drive. Once you replace all the drives, you will then get the extra space automatically. I would advise against using 4TB drives since that's not much of an upgrade. I would look at 6TB at minimum.
Chris Moore
If you have any suggestion about the best practice for this kind of purposes will be appreciated :)
Your idea is not a bad one, but the results wouldn't be very significant. If you replace all six of your 3TB drives with 4TB drives, you only increase your storage by just a little over 3TB. The best 'bang for the buck' last time I looked was 8TB drives.
It won't hurt anything to take the larger disk, but it might not be very helpful in the long run.
vatastala
Thank you guys, so what you think about this...
I can buy an 8TB disk, create a standalone volume and move a lot of data on It...later, when another disk will die ( and some of them are very old, so I think soon) I can add another 8TB...but could I create a mirror when data is already on the first disk?
Chris Moore
Sounds like a risk. Depends on your tolerance for loosing your data.
You can do that from the command line, but there is no feature for that in the GUI.
It is a fairly involved process, so I will link you to a write-up that was done on the process.
https://www.ixsystems.com/community/threads/create-zfs-mirror-by-adding-a-drive.14880/post-453864
