monarchdodra
 - Feb 15, 2012
I installed the ubuntu jail, because I wanted to use a couple of tools I was familiar with. The issue I'm having is that a lot of the networking options (including sudo) that seem to fail. Here is my output:
[root@Odin] ~# jexec 5 /bin/sh
# whoami
root
# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 13.04
Release: 13.04
Codename: raring
# sudo echo hello!
sudo: unable to resolve host buntu
hello!
# ping google.com
ping: icmp open socket: Operation not permitted
# cat /etc/hostname
ubuntu-i386
# cat /etc/hosts
127.0.0.1 localhost
127.0.1.1 ubuntu-i386
# The following lines are desirable for IPv6 capable hosts
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
# sudo apt-get install libjpeg-progs
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
libjpeg-turbo-progs libjpeg-turbo8 libjpeg8
The following NEW packages will be installed:
libjpeg-progs libjpeg-turbo-progs libjpeg-turbo8 libjpeg8
0 upgraded, 4 newly installed, 0 to remove and 59 not upgraded.
Need to get 188 kB/190 kB of archives.
After this operation, 567 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Err http://us.archive.ubuntu.com/ubuntu/ raring/main libjpeg-turbo8 i386 1.2.1-0ubuntu2
404 Not Found [IP: 91.189.91.14 80]
Err http://us.archive.ubuntu.com/ubuntu/ raring/universe libjpeg-turbo-progs i386 1.2.1-0ubuntu2
Err http://us.archive.ubuntu.com/ubuntu/ raring/universe libjpeg-progs i386 8c-2ubuntu7
Failed to fetch http://us.archive.ubuntu.com/ubuntu...-turbo/libjpeg-turbo8_1.2.1-0ubuntu2_i386.deb 404 Not Found [IP: 91.189.91.14 80]
Failed to fetch http://us.archive.ubuntu.com/ubuntu...o/libjpeg-turbo-progs_1.2.1-0ubuntu2_i386.deb 404 Not Found [IP: 91.189.91.14 80]
Failed to fetch http://us.archive.ubuntu.com/ubuntu...peg8-empty/libjpeg-progs_8c-2ubuntu7_i386.deb 404 Not Found [IP: 91.189.91.14 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Anybody know what is going on, and how to fix it?
# whoami
root
# lsb_release -a
Release: 13.04
Codename: raring
# sudo echo hello!
hello!
# ping google.com
# cat /etc/hostname
ubuntu-i386
# cat /etc/hosts
127.0.0.1 localhost
