Suddenly slow write speeds
frank3523
Hello hope someone can help.
All of a sudden I'm having slow write speeds.
My write speed went down from 80Mb/s to 40 Mb/s.
Someone has had the same experience.
William Grzybowski
How full is your pool, write speed can dramatically decrease if you use more than 80-85% or something IIRC.
frank3523
My pool is filled for 27%.
Running the latest release 8.0.3 p1
Made some changes to the aio size, enable it and disable but it makes no difference at all.
frank3523
Solved my problem. It was the nic of my pc causing the problems.
Another nic and all runs fine.
