Running FreeNAS 8.3.2-Release-x64 for a while now. System has dual Intel Xeon E5430 processors, 32GB of RAM, about 20TB on RAIDZ2- drives are connected to a 3ware 9650se-12ML.
From time to time I log into the Web UI and go to the reporting tab just to check the graphs and see how things look. For the longest time I noticed that the Swap Utilization graph had no activity. About 2 weeks ago it started showing about 100MB in use and has hovered around there ever since.
Does this indicate any kind of problem? Is there any way to clear that out? The system is otherwise running fine. I just want to get out in front of any potential issues.
Thanks.
Thanks.
