- Feb 15, 2014
Damn, I had no idea about wdidle. I just bought another green drive!
Can I do smartctl while volume is silvering?
Sure, you can read the SMART data at any time. Just don't overlap SMART tests with heavy IO.
We can tell that you have a "green drive" just by seeing this line:
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1335262
You should have run "wdidle" on the drive before putting it in use.
Please post the smartctl output of the other 2 drives in code tags, so we can view their health.
smartctl -a /dev/ada1
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p7 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family: Western Digital Caviar Green (Adv. Format)
Device Model: WDC WD20EARX-00PASB0
Serial Number: WD-WMAZA5550540
LU WWN Device Id: 5 0014ee 058227628
Firmware Version: 51.0AB51
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Tue Jan 27 17:23:40 2015 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: (37980) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 366) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 173 170 021 Pre-fail Always - 6333
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 403
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 18575
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 392
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 310
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1322603
194 Temperature_Celsius 0x0022 107 098 000 Old_age Always - 43
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 18549 -
# 2 Short offline Completed without error 00% 7488 -
# 3 Short offline Completed without error 00% 7487 -
# 4 Short offline Completed without error 00% 7485 -
# 5 Short offline Completed without error 00% 7484 -
# 6 Short offline Completed without error 00% 7483 -
# 7 Short offline Completed without error 00% 7482 -
# 8 Short offline Completed without error 00% 7481 -
# 9 Short offline Completed without error 00% 7480 -
#10 Short offline Completed without error 00% 7479 -
#11 Short offline Completed without error 00% 7478 -
#12 Short offline Completed without error 00% 7477 -
#13 Short offline Completed without error 00% 7476 -
#14 Short offline Completed without error 00% 7475 -
#15 Short offline Completed without error 00% 7474 -
#16 Short offline Completed without error 00% 7473 -
#17 Short offline Completed without error 00% 7472 -
#18 Short offline Completed without error 00% 7471 -
#19 Short offline Completed without error 00% 7470 -
#20 Short offline Completed without error 00% 7469 -
#21 Short offline Completed without error 00% 7468 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay. smartctl -a /dev/ada2
Device Model: WDC WD20EARX-00ZUDB0
Serial Number: WD-WCC1H0293609
LU WWN Device Id: 5 0014ee 20662aec5
Firmware Version: 80.00A80
ATA Version is: 8
Local Time is: Tue Jan 27 17:25:02 2015 CET
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (40500) seconds.
command.
power-saving mode.
recommended polling time: ( 390) minutes.
3 Spin_Up_Time 0x0027 222 220 021 Pre-fail Always - 7858
9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 18972
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1767951
194 Temperature_Celsius 0x0022 106 097 000 Old_age Always - 44
199 UDMA_CRC_Error_Count 0x0032 200 199 000 Old_age Always - 5849
No Errors Logged
# 1 Short offline Completed without error 00% 18946 -
# 2 Short offline Completed without error 00% 7509 -
# 3 Short offline Completed without error 00% 7508 -
# 4 Short offline Completed without error 00% 7506 -
# 5 Short offline Completed without error 00% 7505 -
# 6 Short offline Completed without error 00% 7504 -
# 7 Short offline Completed without error 00% 7503 -
# 8 Short offline Completed without error 00% 7502 -
# 9 Short offline Completed without error 00% 7501 -
#10 Short offline Completed without error 00% 7500 -
#11 Short offline Completed without error 00% 7499 -
#12 Short offline Completed without error 00% 7498 -
#13 Short offline Completed without error 00% 7497 -
#14 Short offline Completed without error 00% 7496 -
#15 Short offline Completed without error 00% 7495 -
#16 Short offline Completed without error 00% 7494 -
#17 Short offline Completed without error 00% 7493 -
#18 Short offline Completed without error 00% 7492 -
#19 Short offline Completed without error 00% 7491 -
#20 Short offline Completed without error 00% 7490 -
#21 Short offline Completed without error 00% 7489 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1767951
Wow. Nominated for the highest LCC ever. At least the highest I've ever seen. Doing the math, at 18972 power on hours, and the above LCC, the hard drive unloads and loads it's head every 38 seconds.
No wonder we recommend a 300 second load cycle timer.
At some point I see they had short tests configured every hour. I'm personally don't think there's any point. Stick to a long test every week or two and you'll be better off.
Is there any point in using wdidle at this point? From your reaction, I guess they are going to fail soon anyway.
If I connect an external cd-rom player, and boot up with UBCD, can I change my drive settings with WDIDLE3 on all drives at the same time (all of them are wd green disks)?
[root@freenas] ~# zpool status
pool: NAS
state: ONLINE
status: The pool is formatted using an older on-disk format. The pool can
still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'. Once this is done, the
pool will no longer be accessible on older software versions.
scan: scrub repaired 0 in 15h17m with 0 errors on Wed Jan 28 19:47:28 2015
NAME STATE READ WRITE CKS UM
NAS ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/55546f72-a620-11e4-bd23-002522ad0736 ONLINE 0 0 0
ada1 ONLINE 0 0 0
ada2 ONLINE 0 0 0
errors: No known data errors
