Doug Benet
- Feb 25, 2012
I was accessing my FreeNas using SSH - I ran the command REBOOT from the SBIN or BIN folder don't remember which folder. I just ran the command. The system rebooted but then it got stuck with the following message:
Loading /boot/defaults/loader.conf
I did some manual reboot. I also pressed the ESC key to choose the USB boot drive. Tried several options, but I keep getting stuck with the same message.
I was on the way to make a backup of all my configuration.
Don't know what to do. HELP.
I cant afford to lose the files on the FreeNas server.
Thanks
Thanks
