hi
finanlly I succed to put in place for >25 computers (windows 7) a file sarevr based on freenas v9.2.0
(on 9.2.1 it was impossible to map a drive, every time the computer wants user and password and even root was unaccepted)
what can I say:
- the copy 160 gb (and a lot of files) from one 2tb hdd to other identical is a mess (both zfs)
there is not a clear copy task on Freenas interface, a simple copy-paste
after all, I used form shell the command rsync -av --progress (but before I tested tar, cp.., much slower)
Much faster is to map the volumes on windows and copy paste using windows explorer :(
- tried to copy from a ZFS volume to NTFS volume :) with rsync, from shell and at the the first file the server it reboot unexpected
after reboot, almost all previous modification on NTFS volume (rename, delete files and folders over the shared drive) was rolled back automatically :(
- user permission is a mess
If I create a user, this can't be used until reboot
to skip reboot, I used the command "server samba restart" on shell
after this, the user will work and can map drive with him, but, for a while, I can't reopen shell :)
(only a narrow black windows with "Loadding" appear ad dissapear after few seconds)
anyway, on some computers I can't map drive, only access with \\freenas\share and root user :(
for the moment I din't find a good solution to daily copy of that 160gb (and many many files) to other drive
rsync is to slow, the LAN is only 100mbps and there is not to much difference :)
can sombody help me?
thank
what can I say:
thank
