In my server have 1 UFS and 2 NTFS drive.
I installed (first upgraded) new version 9.2.1.6 x64 version and newer to9.2.1.9.
The problem: before upgrade the two NTFS drive samba access from windows 7 worked perfectly.
With the new version I don't know erase files and directories in Windows from the server, from the NTFS drives.
The UFS drive work well.
The copy and make dir work correctly from Windows, only the erase/del and remove dir don't work
When I copy to the NTFS volume the system write error, the drive Read only or similar, but the copy work well, only the erase function wrong.
When I change the NTFS volume owner to guest, it work seemingly.
But the owner not changed, when I look once more.
Any help?
Any help?
