Strange Behaviour
jose.alberto
I just finished the installation of TrueNAS-12.0-U2.1.
I was able to successfully join it to the domain by using the Active Directory Services.
The problem is, as soon i create a pool and perform a restart, the system says this:
Active Directory - FAULTED
To bring it back to Healthy i need to remove the pool and restart the system.
Any clues what can be causing this behavior?
Thanks.
anodos
Sambassador
Thanks.
Might be an issue with system dataset initialization / path. What happens if you create pool, then join AD?
