Storage reading wrong
wheelsca
Thanks for all the help on my first Freenas post, now I have another question.
Trying to learn command line and rsync from one dataset to another. I used this command:
rsync -av --log-file=/mnt/Mount/rsync.log /mnt/Mount/Ccomputers/Edisk mnt/Mount/Ccomputers/TestRsync
It showed everything copying and the shell shows it all as successful. I can change to the directory and see the new directories, I can show directory usage and is shows as 938mb, which is right.
My question is why does the shell show the files but I can't see them on the TestRsync dataset usage and the folder shows empty with a Windows share.
I have attached a pic to show.
Thanks.
Ron
permissions issue? try ls -l from the CLI and see if all looks ok.
Your problem is that you don't have a leading slash on the second path (the target).
Whatever the working directory was when you ran the command will have that structure under it.
