phthatcher
- Dec 8, 2023
New to TrueNAS, a couple decades of computer tech / software dev / network admin / etc.  I understand RAID concepts and approaches.
I'm building a NAS, all new hardware, atx case, ASRock mb, amd cpu, 32g ram. It will primarily serve as a Plex server, but also will have a need to store some documents such as tax returns, wedding photos, etc, no requirements on anything but plex to have read/write performance, and plex already handles read performance so no real requirement there.
I have 2 8TB drives and 2 4TB drives dedicated to storage, and a SSD for the OS. I'm looking for the best method to configure them for storage capacity. They will have offsite backup so redundancy/reliability isn't as much as a concern as storage capacity.
My current Plex server (an older gaming desktop with Win11) is aging and I'm worried about failure (had a drive fail recently) which is the reason for the new build.
So, with 2 8TB and 2 4TB drives (8TB drives are brand new, 4TB drives are 6 months old), what would be an ideal setup for TrueNAS considering I'm prioritizing capacity over redundancy.
From what I've read, I'm thinking I create a pool with 1 vdev containing the two 8TB drives (mirrored), and another pool with 1vdev containing the 4TB drives (mirrored), I can put the Plex movies on one and the Plex TV Shows on another. I'm thinking I'll end up with approx 12TB storage capacity which is good considering my current Plex server has about 7TB. This should give me some local redundancy plus extra space. I'll rely on offsite storage for catastrophic failure.
My concern is, from what I've read, if you lose a vdev you lose the entire pool, so if I put two vdevs (2x 8TB & 2x 4TB) in the same pool, if I lose both 4TB drives I lose everything, hence building two pools with 1 vdev each, maybe I'll lose movies, maybe i'll lose TV shows, but at least I dont lose it all and the offiset recovery doesnt take as long.
Main Question: Would using 2 pools, with 1vdev being 2x 8TB mirrored in 1 pool and 1vdev being 2x 4TB mirrored in the second pool be a good configuration?
